No-lift shift possibly causing knock?
Old Aug 19, 2009 | 12:56 PM
InfraRedline's Avatar
Ive noticed lately since I put my meth in that in between shifts I will get a bit of KR. Im on 23* with an 11.7:1 AFR with zero knock while im pulling, but when I shift (NLS with wot box) sometimes a see a degree or so of KR. Anyone think it could be the ignition cut from the wot box? Im thinking its nothing big but i thought I would just check with everyone.
Old Aug 19, 2009 | 01:00 PM
burnrubr88's Avatar
But you dont get any knock when you shift normal?
Old Aug 19, 2009 | 01:03 PM
BYT*SS*TURBO's Avatar
I have a SS/TC and tune with HPT, I haven't tuned a s/c car so I'm not sure if things are the same. But log the car, where you see the KR goto your timing/spark table and reduce the timing a degree where you're seeing it. Should be less load then WOT, so you prolly haven't messed with that area much. I get a lil KR in 1st at times, I kept logging and working the spot, now it's gone. Hope this helps somehow
Old Aug 19, 2009 | 01:10 PM
Oh good thinking! Ill have to try that out
and Burn, I never shift normal at WOT, I always NLS lol. I could try it though
Old Aug 19, 2009 | 01:16 PM
burnrubr88's Avatar
Do some pulls without using NLS.
Old Aug 19, 2009 | 01:21 PM
If it dries up a little today Il do that for sure. Thanks man!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Tupp
Sep 30, 2015 08:18 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
