No Start - Please help
Old Apr 26, 2010 | 01:25 AM
Angel's Avatar
Ok, well this is my situation in a nutshell. I had converted my car to a Hahn stage V turbo system and many other things such as the OTTP return style fuel system and now I am converting it all back to stock. I have everything done now and reinstalled and my car will NOT fire. It turns over fine and at some points it tries to start but very few and far between. I have a licensed mechanic helping me out to figure this issue but we are at a road block. I will list all the things that have been tested for any of you that are interested;
-All coil packs are good
-We are getting good spark
-We are getting fuel to and through the injectors
-Throttle body is functioning correctly
-We are not tripping any codes
-Voltage is good everywhere
-Grounds are perfect everywhere
-Timing is dead on
-Cam position sensor is set correctly
Things we are leaning towards;
-Crank sensor??? We are getting voltage to the sensor and the sensor is reading around 900 Ohms(Not sure if this is within spec but I dont know what specs are for this sensor)
-Hptuners tune for when I was turbo'd is still on the car(I cannot get the car to a GM dealer to reflash stock tune and no longer own hptuners. I dont think this would cause a "No Start" but who the f knows right about now)
Old Apr 26, 2010 | 10:26 AM
ShortStack's Avatar
If you have the stock injectors in, with hahns tune... Im not sure if it would start either...
Old Apr 26, 2010 | 10:29 AM
rico's Avatar
um turbo set up on all sc stock stuff. maybe idk my car started with a STOCK tune on turbo set up and 80lbs so all depends
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
