Nooooooooooooo!!!!!!!!!!!!!!!!!!!
Old Oct 30, 2006 | 05:09 PM
bdwarr6's Avatar
i have a wideband and will be getting a snow kit shortly
Old Oct 30, 2006 | 05:15 PM
NJHK's Avatar
Did you have a wideband BEFORE your pistons cracked?
Old Oct 30, 2006 | 09:47 PM
eastcoastz's Avatar
Is there an aftermaket piston set out there with stock compression?
Old Oct 30, 2006 | 09:57 PM
NJHK's Avatar
They can be made...
Contact Karo @ Car Customs.net
Old Oct 30, 2006 | 10:04 PM
Blown 4-banger's Avatar
Were you really running a 2.5" pulley with the stock intercooler setup!?!? I have a 2.6" pulley with a cobra heat exchanger AND the dual pass intercooler mod and I STILL worry about heat! Its clear why you blew the motor. I would stick with 9.5:1 compression ratio, another reason for using lower compression with high boost, is because with lots of boost and a high compression ratio, on top of needing to use super high octane race gas, but a lot of the time people have problems lifting the heads off the motor from too much pressure. Also with lower compression you can fit more a/f mixture in the cylenders.
Old Oct 31, 2006 | 04:55 AM
Brian MP5T's Avatar
Originally Posted by Jackalope
CAM 2 to the rescue!
200 Shot to the rescue..
