Is it normal for front wheels to tip in
Old Apr 14, 2008 | 06:55 PM
Bergy's Avatar
I just noticed that the front wheels are leaning in (the top of the wheel is leaning inward) is that how there suppose to sit. Please let me know soon. It only looks like a degree or two.
Old Apr 14, 2008 | 06:56 PM
ssweeet's Avatar
They're supposed to lean in a little bit when the wheel is turned all the way to the left or right. It helps cornering and making u-turns.
Old Apr 14, 2008 | 06:59 PM
TVS_SS's Avatar
this is called negative camber
its designed in from the factory
Old Apr 14, 2008 | 07:08 PM
Altiery54's Avatar
mine do the same. i think i just need an alignment. there definetly not suppose to sit like they are one leans in a good amount while the other is just about parallel. just take it and get an alignment its no big deal
Old Apr 14, 2008 | 09:06 PM
Bergy's Avatar
I just got them aligned like a month ago. So its normal to have have them lean inward a little when the wheel is striaght.
Old Apr 14, 2008 | 09:27 PM
qwikredline's Avatar
make sure if you hit a curb recently that the front knuckle isnt broken between the two lower strut cross bolts, just above the brake rotor.
Old Apr 14, 2008 | 11:10 PM
NexTnmE's Avatar
I noticed this too on my car...it does seem like the front wheels are angled in at the top more than the rear wheels. I'm going to be doing some work on the suspension soon and will be getting an alignment...I'll let you know what my specs are...before and after.
Old Apr 15, 2008 | 10:57 AM
Jeff9000CD's Avatar
as long as the tires dont get an abnormal wear it should be fine
Old Apr 16, 2008 | 05:30 PM
Bergy's Avatar
Thanks guys
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
