Cams
Cams
Anyone know if the intake cam is longer than the exhaust cam on the LSJ? I was told that is was, but im not sure if they are unequal, or equal length, and I need to know ASAP
Shut up about exhaust and use the damn search button!!! See this is the kinda **** that makes people leave websites. Back on topic. The LSJ cams are rare, because it has a cam position sensor. So the cams have a hex type thing in back. Both the intake and exhaust cams are identical (in physical size and shape). The L61 head (2.2L) Has a long intake cam, and the exhaust cam is about 5-6 inches shorter.
**** you! Why don't you go use the search button like all noobs should *******.Order a GM intake cam blank, and have your stock exhaust cam reground. Thats what I WAS gonna do, but they ground my cams backwards, so I had to send them my other stock cam.
Problem handled. Moving on...
they are already insanely priced anyways!
no two regrinds are the same. as im finding out.
blah!
also, if you can't tune, or have no idea how to do it. cams are a bad idea.
blah!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
