O2 extender
i donno if its needed but i kept tripping the p0420 low cat efficiency code. i put spark plug anti-foulers on the end of the o2 and it was fine for over a year and now its starting to come back on again. i cleared the light on sat and was bck on like 15 mins later
An extension will help on a catted system. The primary reason to having them is to prevent the sensor from burning out. Catted exhausts get much hotter than non-catted exhausts. I would say yes, put one in for safety.
o, ok. It will help if you don't want to look at a cel. But not necesary.
clearing the lights will only reset the monitors... once the monitors go through their cycle, the code will be set again.
A high flow cat is going to possibly throw a cel. The cel does nothing, means nothing.
Another possibility is to have the code turned off through hptuners. That way that code will never show up again, but will still allow other codes to pop up.
Either way, like said already the codes (whether they're for the cat, secondary 02 sensor, or both) won't affect anything other than having your engine light on. Can always get it turned off.
so would there be no effect on performance if i was to just elminate the second O2 and plug it? If theres gonna be a cel no matter what i do until i get hptuned, its pointless to let it sit there
mine had been broken for well over a year, and there has been zero loss of performance.
i got a O2 sensor right angle extender off ebay as u cant really find it anywhere haha it was 27 bucks i think
i got it cuz of the high flow cat on my downpipe, i had a code thrown but it was cuz my exhaust had a big leak, as it set off the code on and off till i tighten up the header a week later as it loosen after the 1st week
