O2 extender
Old Oct 19, 2009 | 07:34 PM
TurboTommy's Avatar
O2 extender
Is it necessary to have an o2 extender with a high flow cat?
Old Oct 19, 2009 | 07:43 PM
bobbyhill31286's Avatar
i donno if its needed but i kept tripping the p0420 low cat efficiency code. i put spark plug anti-foulers on the end of the o2 and it was fine for over a year and now its starting to come back on again. i cleared the light on sat and was bck on like 15 mins later
Old Oct 19, 2009 | 07:45 PM
TurboTommy's Avatar
interesting....I wonder if I should just go ahead and put one on.
Old Oct 19, 2009 | 07:49 PM
1BADSS/SC's Avatar
An extension will help on a catted system. The primary reason to having them is to prevent the sensor from burning out. Catted exhausts get much hotter than non-catted exhausts. I would say yes, put one in for safety.
Old Oct 19, 2009 | 07:56 PM
D4u2s0t's Avatar
depends what you're talking about... are you talking about the wire that increases the length of the harness? like what zzp has with their setup? Or are you talking about something different.
Old Oct 19, 2009 | 08:14 PM
TurboTommy's Avatar
no...an extender that actually pulls the o2 sensor out of the gas flow
Old Oct 19, 2009 | 08:34 PM
D4u2s0t's Avatar
o, ok. It will help if you don't want to look at a cel. But not necesary.
clearing the lights will only reset the monitors... once the monitors go through their cycle, the code will be set again.
Old Oct 19, 2009 | 08:44 PM
TurboTommy's Avatar
Is it pretty much a given that your gonna get a cel with a high flow?
Old Oct 19, 2009 | 10:48 PM
ddsscobalt's Avatar
i second that question turbotommy... idk if i have a cel because of the high flow, or because i melted wires from the O2 touching the metal heatshield above the dp
Old Oct 20, 2009 | 11:11 AM
TurboTommy's Avatar
any other opinions?
Last edited by TurboTommy; Oct 20, 2009 at 11:11 AM. Reason: Automerged Doublepost
Old Oct 20, 2009 | 11:22 AM
Bl4des's Avatar
just have that cel turned off you are tuned
Old Oct 20, 2009 | 11:23 AM
ShortStack's Avatar
A high flow cat is going to possibly throw a cel. The cel does nothing, means nothing.
Another possibility is to have the code turned off through hptuners. That way that code will never show up again, but will still allow other codes to pop up.
Old Oct 20, 2009 | 11:33 AM
D4u2s0t's Avatar
it's very, verly likely. May come on right away, may take a week, may take a year. But it's a very high possibility you will get one with no or even a hi flow cat.
pick yourself up a cheap code reader. You will know right away. The wires most likely won't melt, that's where they're designed to go, so they're designed to stand up to some heat.
Either way, like said already the codes (whether they're for the cat, secondary 02 sensor, or both) won't affect anything other than having your engine light on. Can always get it turned off.
Old Oct 20, 2009 | 03:00 PM
ddsscobalt's Avatar
so would there be no effect on performance if i was to just elminate the second O2 and plug it? If theres gonna be a cel no matter what i do until i get hptuned, its pointless to let it sit there
Old Oct 20, 2009 | 03:15 PM
ShortStack's Avatar
No, because the second o2 sensor still works with COT managment in the ECU.
This can sometimes cause some power issues if the o2 is removed without having it tuned out.
Old Oct 20, 2009 | 03:18 PM
D4u2s0t's Avatar
mine had been broken for well over a year, and there has been zero loss of performance.
Old Oct 20, 2009 | 03:27 PM
i got a O2 sensor right angle extender off ebay as u cant really find it anywhere haha it was 27 bucks i think
i got it cuz of the high flow cat on my downpipe, i had a code thrown but it was cuz my exhaust had a big leak, as it set off the code on and off till i tighten up the header a week later as it loosen after the 1st week
Turbo Wax
TurboWax
Jan 23, 2006 07:43 PM
JonyyB
Aug 4, 2005 07:41 PM
