O2 sensors Interchangeable?
Old Nov 24, 2009 | 12:36 AM
InfraRedline's Avatar
Ive been throwing a P1133 code lately, and I think it may be due to no lift shifting and burning out my primary O2 sensor...but I could be wrong.
Basically what I want to know is can I unplug my primary sensor and put my downstream one in its place since it isnt even in the car anymore? Or are they tow completely different sensors?
Thanks guys
Old Nov 24, 2009 | 05:48 AM
GPZRider96's Avatar
p1133 ftl... i've been throwing that ever since the flood. that was my useless post for the day since i really can't answer your question sorry lol
Old Nov 24, 2009 | 06:32 PM
StevesBlack06's Avatar
you cant do it. the primary o2 sensor is treated to withstand a sertain temperature rating. you will burn it up for sure if you put yur downstream in its place. the primary sensor is pricey but you gotta pay to play
Old Nov 24, 2009 | 07:33 PM
Damn no lift shift screwin it up lol. Thanks man
Old Nov 24, 2009 | 08:40 PM
i dunno why your NLS would mess it up unless its totally burned to **** due to the extra fuel igniting in the exhaust. they are usually rated for a really high temp. but its understandable. i just bought a primary sensor and if i remember correctly (which dosnt happen often) i paid like a hundo for it
Old Nov 24, 2009 | 08:50 PM
383_Stroker's Avatar
amazon is your friend..
http://www.amazon.com/Bosch-13455-Ox.../dp/B000BZJ7CG
sucker is 132 at advance auto... 43 on amazon.. go figure
ps: i've ordered two from there (long story), both came in 2 days
Last edited by 383_Stroker; Nov 24, 2009 at 08:50 PM. Reason: Automerged Doublepost
Old Nov 24, 2009 | 09:13 PM
i always forget about amazon... fml
Old Nov 24, 2009 | 09:37 PM
Thanks dustin! That makes it way easier on the wallet. I think 2-stepping and NLS made it start to go for some reason since the CEL usually comes on after that. The car runs fine so Ill let it go for a while and maybe try to clean it. Thanks guys!
Old Nov 24, 2009 | 09:43 PM
recklessactn's Avatar
YES amazon ftw, I also replaced my rear o2 with the better than OE replacement o2 sensor and Ive had no problem throwing codes since.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
