Odd Issue with 2.0 LSJ
Old Nov 30, 2010 | 04:30 PM
  #51
NightriderCobaltSS's Avatar
Originally Posted by Chevycobaltss3
So u need to rip her apart and look what u need to replace.
the oil itself doesnt look milky ..they it if you have bad comtaimantion it should look like choclatte milk ? and currently no white smoke so lets pray it was a small leak and didnt **** nothing up
Old Nov 30, 2010 | 05:43 PM
  #52
Chevycobaltss3's Avatar
Well if it is only on the cap u can be getting it from say the head hasket, crack in the head or block or some warpage. Or even humid air somehow got into ure engine by say leaving the oil cap off whwn it was raining, or u purposly put water in ure oil. . Ha ha funny rigjt. More then likely u have a bad head gasket. U could possibly tighten the head down,about 5-10 more ftt lbs when a torque wrench. It sometimes will work depending on how bad thr head gasket is. Our head gaskets are metal ply gaskets so they can't seperate easily. So try it and let me know.
Old Dec 2, 2010 | 08:46 PM
  #53
shredout's Avatar
so, when changing a head gasket, should one consider the Cometic gaskets??
are they better than an OE replacement?
Old Dec 2, 2010 | 09:26 PM
  #54
I myself would so a cometic, but and.I say but tighten the head down to specs and after 300 miles tighten it down 5 more ft lbs and after another 100 tighten again 5-10 more ft lbs. Just trust me on this.
Old Dec 8, 2010 | 07:38 PM
  #55
shredout's Avatar
well i will definately heed ur warnings. thanks much.
Old Dec 8, 2010 | 07:48 PM
  #56
U r welcome. Any updates op.
Old Feb 9, 2011 | 05:31 PM
  #57
Had a local shop take a look at appearently it was the water pump...odd...they said bolts were missing seals broken...they said it looks like someone F*cked it up...
Old Feb 10, 2011 | 12:51 AM
  #58
wut prob happen is they got loose and went into the oil pan and caused the **** to screw up
Old Feb 10, 2011 | 03:35 PM
  #59
red06SC's Avatar
Originally Posted by JetBlackSS
Mine was leaking from here once. One of the washers wasn't in place. Never found any coolant because it only leaked under pressure and burnt off while driving.
wat
that is a fuel line...
Old Feb 10, 2011 | 09:37 PM
  #60
xxxxsh4d0wxxxx's Avatar
Originally Posted by red06SC
wat
Behind it is a coolant line.
Old Feb 12, 2011 | 06:14 PM
  #61
SSQT125J's Avatar
how did they figure out it was the water pump? im having the same problem and was leaning towards the head gasket but im not getting any white smoke either.
Old Feb 14, 2011 | 02:12 PM
  #62
they put the car in the air and saw there were bolts missing from the water pump...and it had back out a little...
Old Feb 23, 2011 | 07:25 PM
  #63
Yea that didnt last long...now ive had the resivor and the water pump replaced and im grabbing at straws....to figure out what the issue could be i lose most of the coolnat os the resivor every 3 to 4 days...
Old Feb 23, 2011 | 08:15 PM
  #64
if you have done a leak down test, a compression test, and all past, then only other wy it can be leaking or burning is, if you have a bad head gasket that is leaking into the oil just enough to evaporate. or you can have sleeve issues. check for condensation in the oil after a pressure test with the coolant, you will find a leak quickly. If the shop working on your car is smart and know what they are doing then theyll see this quickly
Old Apr 30, 2011 | 08:33 AM
  #65
Pacman7369's Avatar
Sticky lifters there my friend. check your oil to see if ur low. whats happening is the oil isnt stayin up in the lifters so theres no oil to lubricate them. i had the same prob so i just changed my oil and replaced one quart with Lucas oil stabilizer synthetic and havent heard it since
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
