Official Turbo LSJ thread!!!
#5976
#5977
nope, the efficiency of a turbo can be based on many different things, head, ports, exhaust, blah blah. But no matter where you are the power is going to be similar. SO if your turbo is more than a 20g you may be at 18 psi and flow much more air and run out of fuel, but you will still probably be around the 420 whp mark.
Compressor efficiency is a measure of how well the compressor wheel uses its kinetic energy to compress air
go read here lots of good info
Not2Fast: Turbo Glossary
#5979
If you could afford to buy it in drum fulls or like fuel oil is stored. Yeah. The better thing if you are on a budget is to have two tunes one for E and one for 93. Just dont forget to turn down your boost controller or POP. Run the E when you can cart back enough every once in a while.
#5982
There are several words in that glossary that use the word efficiency. I was just saying that the turbos CFM is more important than the PSI. His PSI will be lower than mine based on the turbos ability to move air but still make the same horsepower.
My 2.0 makes its max efficiency at 27 psi on the 20g. Hahns 1.4 Liter motorcylce with a 20g strapped on it will make that power at a much higher rpm at 34 psi, but the turbo is still flowing the same CFM.
The PSI is just a way to measure what the turbo is doing, as you said based off the turbo graph.
#5983
if you can keep the E sealed a month will keep no problem. As was said dont let water get in there. E absorbs water like a sponge.
How is ZZP achieving this "race" file on the LSJ?
Tuning options include no ECM file, standard ECM file for setups up to 375whp(customer provides ECM core), standard file with core included, race file for setups up to 500whp(customer provides ECM core), or race file with core included. The race file option includes the following upgrades:
Adjustable launch control rev limiter 2500-5500
Raised ceiling for MAF sensor table for much higher HP potential
ECM tuning capability for boost levels up to 28psi
Full MAP scaling adjusts fuel up to 25psi boost pressures
Revised cooling fan control capabilities
High octane mode
Nitrous input
High octane mode
Nitrous input
#5985
#5986
What would you recommend for me to do and use for a fuel system? You help me build a good build an awesome fuel system. If your willing, ill drive to you for a tune. Id prefer yours as itd be better then most that like to cheap out and take the quick route on tuning
#5988
#5989
I want to see 600whp I think with enough fuel and a great tune my 2.1 girdled block p&p'd head stg2 cams s256et and 6spd and slicks will net me a high 10sec 1/4mi with good launch and traction. But I need the fuel system to support it on e85 and bring it all together
#5991
Anyone interested in a full never used devils own meth kit? It comes with a 6gal trunk mounted tank, 3, 5, and 7 gph nozzles and spacer. Also have 4 gallons of meth to go with it. It is the total package. I don't have to sell it just looking to get what a paid for it if not a little less. I will just maybe use it if I can't get what I want for it. 400 dollars plus shipping just figured I'd post in here before making a classified thread. Thanks
#5992
Any one have feed back on this pump dropping in our tanks? I have walbro 255 now. Think I could do a lil more modification to make this pump fit in our tanks? Or will it not fit at all?
http://item.mobileweb.ebay.com/viewi...d=321035314959
#5993
#5995
I'm on a Ottp return fuel system and ID1000 injectors. The pump worked just fine. But idk what the car was putting down, I was on a built zzp block and #1 cylinder exploded. So I'm not sure what I'll be doing with the car..
#5996
Damn man. I have the same ottp rsf. Looking to r3place the walbro 255 due to I think its starting to fail. And upgrading my 80# injectors. Did you get any runs at the track before it popped3d? Who did the tuning?
#5998
Nope it destroyed it. Atleast the block gaurd held the sleeve walls together but it looks like it broke the bottom of the block and the whole sleeve was in the oil pan. Destroyed the piston and valves in cylinder 1
#6000
well i went racing tongiht and my MBC is the biggest piece of crap ever. My boost wsa back down to wastegate spring psi (15) and made the car feel slow. The TUrboxs hpbc is crap. I got out a 2mm wrench turned it counterclock and was back up to 19 psi. Did it again and was back up to 23. So the stupid thing doesnt hold its setting. the set screw is garbage. Time to get an electronic boost controller...
edit: i found out my hahn manifold is cracked and leaking boost again, the MBC is fine.
