Official TVS Thread!!!
Old Apr 10, 2013 | 02:11 AM
  #5526
RooTBeeR's Avatar
Old Apr 10, 2013 | 08:50 AM
  #5527
100% METH's Avatar
You guys comparing a k20 to the lsj again?
Old Apr 10, 2013 | 09:04 AM
  #5528
Staged07SS's Avatar
Administrator
Administrator
Old Apr 10, 2013 | 09:20 AM
  #5529
dead horse - meet beating.
Old Apr 10, 2013 | 09:34 AM
  #5530
jonathan923's Avatar
the 1900 fit with some hacking to the front by the pulley.
3.6 pulley, 25-26 psi... I'm all for big blowers... even with a hogged head and a 2.4... a 2300 may just be to much.
holy ****! thats like 3 m62s strapped together..
now, how do you even tightened the bolts on that thing? thats crazy
Old Apr 10, 2013 | 12:37 PM
  #5531
armcclure's Avatar
Originally Posted by bratboy90
I'm betting $20 that he makes power.... dumbest statement ever. Now is it better than smaller blowers I don't know...
Holy **** über tooner take a dose of sarcasm and sit the **** down.
Old Apr 10, 2013 | 12:42 PM
  #5532
RooTBeeR's Avatar
No, k24
you don't, the intake and a belt hold on
Old Apr 11, 2013 | 12:09 AM
  #5533
100% METH's Avatar
Lol
It was a tight fit
Old Apr 11, 2013 | 12:32 AM
  #5534
RooTBeeR's Avatar
It sure made a pretty nice loud whine on your car too
Old Apr 11, 2013 | 08:29 PM
  #5535
wRcKLes's Avatar
Kinda a n00b question but will the 3.1 pully on a tvs fit with a pheolnic spacer and the stock belt?
Old Apr 11, 2013 | 09:13 PM
  #5536
JapEatr's Avatar
South Central *********
Yes
Old Apr 11, 2013 | 09:24 PM
  #5537
wRcKLes's Avatar
Thanks again
Old Apr 11, 2013 | 09:47 PM
  #5538
Powell Race Parts's Avatar
baby dont do it. lol
Old Apr 11, 2013 | 10:24 PM
  #5539
ThexGovenor's Avatar
Should be able to go below a 3.1 pulley though.
Old Apr 12, 2013 | 08:48 AM
  #5540
100% METH's Avatar
Yeah it whined a lot for a 3.6 pulley
I hve video of it on my computer at home
Old Apr 12, 2013 | 06:17 PM
  #5541
Tjolley's Avatar
Originally Posted by 574
TVS 1900 + 2.4 stroker... lawd why hasn't anyone done this?!
(I already know, lack of money. It was a rhetorical question)
But seriously someone needs to do this
I think the le5 crank is only good to 600-700 hp..Im afraid to break it but if that happens then ill have to buy a gen3 block and have crower custom make me a crank with 112mm stroke on it.. 2.7 stroker oh ya.
Another 8k into the car.
The only thing holding me back from the 1900 now is my trans. Im not sure if the issue is the trans or the cables. If it ends up being a trans issue im gona do a f40 swap.
Old Apr 12, 2013 | 06:26 PM
  #5542
armcclure's Avatar
I think a lot if people should stop being so scared of properly set up nitrous...
Old Apr 12, 2013 | 06:29 PM
  #5543
Area47's Avatar
Rent me! per hour
most people don't know how
Old Apr 12, 2013 | 06:31 PM
  #5544
armcclure's Avatar
True. And the stereotype it received from all the f&f movies sure didn't help. I'm setting mine up with a lazy blower and a nitrous express kit ran off of a maximizer4 progressive controller. With a nano nitrous assist kit.
The things you can do with the NEW max4 controller (not FS to public yet, I'm special.) are crazy. Complete control of everything.
Old Apr 12, 2013 | 06:41 PM
  #5545
Area47's Avatar
Rent me! per hour
probably similar to the old fjo controller
Old Apr 12, 2013 | 06:45 PM
  #5546
Tjolley's Avatar
I just like it to hit at 3500 to 7250. 75shot seems to do the trick at keeping the iat2s in check.
Old Apr 12, 2013 | 07:29 PM
  #5547
armcclure's Avatar
Similar. But better. The original had tons of options, this one you can use all of them together. For example, set a base %, say 25% at 50 mph to 100% at 80. Then you can still ramp in at a desired rate on top of that after shifting.
Then run your wideband 0-5 into it for compete safety. Tell it your target afr and if something changes in the system, either bottle pressure drop or a fuel pressure drop, even fuel failure, it will automatically vary the solenoid pw to maintain that afr, to the point of shutting the system off in case of a fuel failure.
I'm excited.
Old Apr 14, 2013 | 06:13 PM
  #5548
Blairwolf's Avatar
I just sent a head to lsjion, should i have him port just the exhaust side or do intake and exhaust? I will be running stage 2 cams. Other mods are in my sig.
Old Apr 14, 2013 | 06:19 PM
  #5549
armcclure's Avatar
I think you should untrust that to him. He usually does a very mild flashing cleanup on the intake iirc.
Old Apr 14, 2013 | 06:22 PM
  #5550
I dont think it is possible to open up the exhaust enough to maintain the balance inlet/exhaust that is needed. If we assume that GM racing were correct, and just porting the exhaust gave the right performance balance for the supercharged engine, with the existing inlet port, it makes sense that if you open up the inlet any, you need to go even bigger on the exhaust port than the GMR CNC exhaust port config. That is possible based on my flow numbers from bench testing, but if it was my money I would only do the exhaust. Billabong has had some good results though.
I run GMR heads.
