Official TVS Thread!!!
Old 08-06-2013, 02:04 PM
  #6401
armcclure's Avatar
Originally Posted by JapEatr
**** now im scared... i hadnt thought about that... my grimm thoughts were that i snagged a wire drilling holes for my roll cage and had a short
cus pulling that cage back out is a MF'r
Just stop and think what would happen if the belt stopped moving, then reread infras post
Old 08-06-2013, 02:12 PM
  #6402
South Central *********
JapEatr's Avatar
I have a ATI damper, theoretically i could have spun the damper on the crank. but i think the alt just is being gay
Old 08-06-2013, 03:11 PM
  #6403
armcclure's Avatar
Jap, what does the belt drive other than the alt...
Old 08-06-2013, 03:54 PM
  #6404
InfraRedline's Avatar
The thing that this thread is all about lol
Old 08-06-2013, 04:08 PM
  #6405
JapEatr's Avatar
Alan... Lol i got it, at the time i knew it wasnt that because the ac still worked and had boost.
But my point was even if i sheared the crank key way, the damper is pressed on, it wouldnt spin in place
I think the alt may be on the outs or my Volt meter is wrong by a couple volts
I showed 11.6V when i put it on the battery posts with car running
Old 08-06-2013, 05:43 PM
  #6406
mrbelvedere's Avatar
if you shear the key the ati will spin on the snout it only has 5tenths press which is not much that is one reason why I extend the keyway
Old 08-06-2013, 05:52 PM
  #6407
JapEatr's Avatar
Extened keyway makes the fffr easier to install as well
Old 08-06-2013, 10:45 PM
  #6408
OttawaMark's Avatar
Anyone pull an ATI off? That day is coming and I've got some ideas but nothing concrete.
Old 08-06-2013, 10:48 PM
  #6409
JapEatr's Avatar
Pull the bolts in the damper and thread a couple bolts in there as jackscrews
Old 08-06-2013, 10:50 PM
  #6410
yea get a puller and remove 3 of the torx bolts and pull it off
Old 08-06-2013, 11:14 PM
  #6411
Tjolley's Avatar
Ya i pulled steves off
Have to take the engine mount loose to get the dampaner off.
T40 and T45 torx socket needed
Then used a pulley puller or somethin to pull the hub off.
Old 08-06-2013, 11:20 PM
  #6412
100% METH's Avatar
I can be done!
Old 08-06-2013, 11:22 PM
  #6413
Tjolley's Avatar
Steve watched me do most the work with the wheel on. Lol
Old 08-06-2013, 11:27 PM
  #6414
100% METH's Avatar
this is true
I was making Pizza
Old 08-06-2013, 11:28 PM
  #6415
Tjolley's Avatar
Bomb pizza
Old 08-07-2013, 09:56 AM
  #6416
Melon's Avatar
I like pizza
Old 08-07-2013, 10:36 AM
  #6417
JapEatr's Avatar
im installing one on Hockeymans car this evening, think im gonna tap it on with a mallet to start it then use the old crank pulley bolt to push it on
Old 08-07-2013, 10:42 AM
  #6418
Melon's Avatar
Tjolley ill make u a deal, when time comes and if ur able/want to. Ill cook u steak in exchange for ur help swapping out heads and s/c's....
Old 08-07-2013, 10:52 AM
  #6419
I wouldn't tap it on you could damage the thrust bearing go get a long piece of all thread and a nut and washer and put it on correctly
Old 08-07-2013, 10:56 AM
  #6420
Tennpenn83's Avatar
^^ This. I damaged a thrust bearing on the crank in my old motor putting the ATI on with a hammer. I didn't whale on it either, just slowly tapping it in.
Old 08-07-2013, 10:57 AM
  #6421
Got Bewst?
Bluelightning's Avatar
I used a heat gun and heated the middle where the crank slides on for about 5 min. The ATI slid on about 50% of the way then I just used the crank bolt for the rest. Makes it much easier knowing you are lining everything up before cranking it down with the bolt.
Old 08-07-2013, 11:11 AM
  #6422
Tjolley's Avatar
Im down
Swaping a head is easy. Couple hours.
Ask steve we had his head off in proly 2 1/2 hrs and that will taking a pizza break. Lol
Can be done faster with out interuption.
Old 08-07-2013, 11:41 AM
  #6423
JapEatr's Avatar
How much did you clearance the timing cover?
Old 08-07-2013, 11:52 AM
  #6424
Got Bewst?
Not much actually. I had the cover off when I did it so I could mock up the ati and belt clearance as I took away material. Otherwise on the car you're hoping you've taken off enough and pressing that ATI on.
Old 08-07-2013, 11:58 AM
  #6425
JapEatr's Avatar
got a pic?
Quick Reply: Official TVS Thread!!!
