Official TVS Thread!!!
Old Nov 13, 2016 | 05:42 PM
  #10301
07blackg5's Avatar
Slobodan Milošević
What is going backwards? I'm saying the lsj has a better rod/stroke ratio than the l61
Old Nov 14, 2016 | 11:36 AM
  #10302
100% METH's Avatar
He' saying the rod itself is physically longer
Old Nov 14, 2016 | 11:43 AM
  #10303
07blackg5's Avatar
Slobodan Milošević
the rod is longer, yes, but the rod ratio is much worse than the lsj. Just because the rod is longer doesn't mean that it rotates more freely. the rod length is only part of the equation.
Originally Posted by Tjolley
remember mike has rod ratio on his side also. the 2.2 rod is a lot longer than a LSJ rod. engine runs much more freely.
Old Nov 14, 2016 | 01:05 PM
  #10304
63 Nova SS's Avatar
I'm agreeing with you. Typically longer rod gets you to shorter crank length (faster rotating) or shorter piston (less weight to rotate). My gen 1 sbc 406 came with 5.56 rods and it now has 5.7's. wish I would have spent the money and thrown 6.0 in it. Shorter piston, less weight, easier to handle higher rpm.
Old Nov 19, 2016 | 08:40 PM
  #10305
mrbelvedere's Avatar
the rod does not shorten anything with the crankshaft, the rod length changes piston speed at different points in the stroke and where the piston sets in the bore during travel, a longer rod gives you less side load on the cylinder and is easier on the rod bearings so it cuts friction and as for it is divided up into 2 parts half of the rod and piston goes to rotational weight the other half goes to static weight
Old Nov 19, 2016 | 08:59 PM
  #10306
63 Nova SS's Avatar
Yeah I didn't say that right. I'm thinking total crank movement. You surely knew what I meant.
Old Dec 2, 2016 | 07:43 PM
  #10307
Rob Loewen's Avatar
Question
Hey i have an 06 cobalt ss 2.0 eco tec and when i got it i swear i hear the supercharger wine alot more than i do now is this possible without adding any mods
Old Dec 10, 2016 | 05:35 PM
  #10308
Blairwolf's Avatar
Anyone here have 3.0" TVS pulley they don't need. Went back to pump gas and the 2.8 is a little much.
Old Dec 11, 2016 | 05:01 PM
  #10309
I had a 2.8 on pump gas. whats the issue?
Old Dec 11, 2016 | 05:11 PM
  #10310
Blairwolf's Avatar
I am in the process of selling the car and the guy who is interested wanted to know about getting it tuned without the meth injection. So far the car doesn't like any timing with the 2.8 and shitty 91 pump. Thinking of going up to a 2.9 or 3.0 to help it out a little.
Old Dec 11, 2016 | 05:19 PM
  #10311
no option for 93? I ran shell 93. What does he want to get rid of the meth for? I ran it on washerfluid and yellow bottles of heet. Can be found at any walmart and honestly i really only filled it less than maybe 5 times a year (2.5 gallon tank in trunk )
Old Jun 14, 2017 | 08:59 AM
  #10312
advise's Avatar
best thread around and its dead
Old Jun 14, 2017 | 10:27 AM
  #10313
chevygirl2006's Avatar
I recently joined the tvs gang 3 weeks ago ��
Old Jun 14, 2017 | 10:50 AM
  #10314
jdbaugh1's Avatar
Very nice
Old Jun 14, 2017 | 11:59 AM
  #10315
07blackg5's Avatar
Slobodan Milošević
Still sending it with my stock sleeve gen 2 block lol
Old Jun 14, 2017 | 01:50 PM
  #10316
heeter_33's Avatar
Both look great.
  #10317
Very clean. Remove that pcm cover. It's getting smooshed lol
Old Jun 14, 2017 | 02:07 PM
  #10318
07blackg5's Avatar
Slobodan Milošević
Thanks. it's actually filthy, but the lighting was just right haha.
and the cover is trimmed. it's not bend behind, it's cut off. Old pic, but you can see it better:
Old Jun 14, 2017 | 02:12 PM
  #10319
jdbaugh1's Avatar
Old Jun 14, 2017 | 02:13 PM
  #10320
Cleaner than a lot of engine bays regardless.
Old Jun 14, 2017 | 02:16 PM
  #10321
jdbaugh1's Avatar
I noticed in those last couple of pictures that you both have some sort of return type fuel system with regulator? Did you add that or did your cars come that way? What are the advantages?
Old Jun 14, 2017 | 02:30 PM
  #10322
They are aftermarket. Allows more fuel when you get to point of bigger builds. Also allows you to regulate fuel pressure.
Old Jun 14, 2017 | 02:40 PM
  #10323
jdbaugh1's Avatar
You both running E85? Where do you get fuel systems? Fairly straightforward conversion?
Sorry for all the questions just something I never considered and didn't know I might need.
Old Jun 14, 2017 | 02:42 PM
  #10324
advise's Avatar
OTTP sells a kit
Old Jun 14, 2017 | 02:43 PM
  #10325
Depends on your setup if you would benefit. Zzp has it as well as summit racing. That's where I got mine. But I don't just have the boost reference system. I also have the walbro 450 fuel pump and 160# injectors. And yes I'm on e85
