Oil!!
Old Mar 29, 2008 | 11:36 AM
Cyclone's Avatar
Oil!!
How much oil does our car's take ??? 5-6Q??
Old Mar 29, 2008 | 11:42 AM
rmorris003's Avatar
read your manual
Old Mar 29, 2008 | 12:04 PM
srowler9's Avatar
almost 7
Old Mar 29, 2008 | 12:11 PM
CobaltSS 16's Avatar
The manual says 6 I think, but in reality more like 6.5 quarts.
Old Mar 29, 2008 | 12:14 PM
TxLonghorn#1's Avatar
too ****** much...considering I use Royle Purple
Old Mar 29, 2008 | 01:28 PM
2K5SS/SC?'s Avatar
6 quarts and a little to top it off.
Old Mar 29, 2008 | 02:20 PM
jimmyfoxx's Avatar
i just buy a case of 6, good enough. gotta love costco lol
Old Apr 2, 2008 | 07:06 PM
Cyclone's Avatar
Ok so i did my oil change and let my car sit for eigth hours after so,and know that i check my oil im still a lil low like a 1/4 to 1/2 of a quort is this right can anyone verify this thanks!!!
Old Apr 2, 2008 | 07:16 PM
nich7601's Avatar
There's no reason to let it sit for 8 hours, if that was the only reason you did...anyways, yea, thats about right. Top it off if you want, I always just put in 6 and be done with it.
Old Apr 2, 2008 | 07:28 PM
jimmyfoxx's Avatar
yeah same here, 6 is good enough
Old Apr 2, 2008 | 07:32 PM
chris88z24's Avatar
Put in 6, start engine for a few seconds, stop.. check oil, add as necessary until Full is reached. Usually somewhere around 6.25-6.5 quarts.
Old Apr 2, 2008 | 07:37 PM
Tomtwtwtw's Avatar
Why would you do that? Dipstick readings should be taken when no oil is in the engine. i.e. not right after it was turned off. You run the risk of overfilling it if you do.
Old Apr 2, 2008 | 07:41 PM
nich7601's Avatar
This is news to me...my father, who has been a mechanic since before I was born, has taught me to do that since I started driving. And, the overfill problem is solved by simply reading the manual to get a half-assed idea of how much oil you need.
Old Apr 2, 2008 | 07:44 PM
boostedss26's Avatar
a **** hair over 6
Old Apr 2, 2008 | 07:47 PM
GreenPurgatory's Avatar
Originally Posted by boostedss26
a **** hair over 6
lol, yeah, I put 6.5 last time and I am over. It takes 6.
Question: Why is it bad to go over, even if by just half a qt?
Old Apr 2, 2008 | 07:51 PM
Tomtwtwtw's Avatar
Half quart probably won't hurt, but look at it this way - your car parts just dip themselves in oil. Put in too much, and they'll be swimming in it.
If the OP was reading the manual, do you think they'd be posting here?
And the manual tells you exactly how much you need. The half-assed ideas tend to come from threads such as these.
Old Apr 2, 2008 | 07:57 PM
chris88z24's Avatar
No you don't.. you're supposed to check the oil with the engine "warm" after it has been sitting for a few minutes on level ground.
"In order to get an accurate reading, the oil must be warm and the vehicle must be on level ground."
1. Turn off engine and wait several minutes for oil to drain back into the pan. If you do not do this, the oil dipstick might not show the actual level.
Tomtwtwtw's Avatar
Yeah, that's exactly what I said, but in different words. You need to let the oil drain back into the crankcase. Of course, if you wait all night, you'll want to warm up the engine and then wait a few minutes. Cold oil expands, and can throw off your reading.
Old Apr 2, 2008 | 08:00 PM
blk ss/sc 1's Avatar
6.5 is what i use
bigrroberto's Avatar
doesnt it expand when warmer?
Old Apr 3, 2008 | 12:23 AM
rukkee's Avatar
From GM Service Information
xTooltipElement Service Information
2006 Chevrolet Cobalt | Cobalt, Pursuit (VIN A) Service Manual | Bulletins By Category | Technical | Document ID: 1593070
Approximate Fluid Capacities
The following approximate capacities are given in English and metric conversions. See Fluid and Lubricant Recommendations for more information. All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this manual. Recheck fluid level after filling.
Application
Specification
Metric
English
Engine Oil With Filter
2.0L L4 Engine Supercharged - RPO LSJ
6.0 liters
6.3 quarts
Cooling System
5.7 liters
6.0 quarts
Intercooler System 2.0L Engine - RPO LSJ
1.9 liters
2.0 quarts
Fuel Tank
51.1 liters
13.5 gallons
Transmission/Transaxle
Transaxle, Manual - MU3
1.9 liters
2.0 quarts
© 2008 General Motors Corporation. All rights reserved.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
