oil change..
Old Jul 19, 2010 | 09:23 PM
Rob9_ss's Avatar
oil change..
i dont know too much about my lsj and was told that the oil filter was underneath the twin screw supercharger. went to get my first oil change at midas way back and i was charged 90some..anyone know where they do it cheaper with the mobil 1oil? thanks.
Old Jul 19, 2010 | 09:24 PM
ramrod1337's Avatar
Ya do it yourself for 60
Old Jul 19, 2010 | 09:26 PM
SSBlack06balt's Avatar
A local pennzoil or something like that would do it for around 70. Pennzoil Ultra ftmfw btw, but use what you like.
Old Jul 20, 2010 | 04:34 PM
Laser Target's Avatar
Ya its not too hard to do it your self and its worth saving 30 bucks
Old Jul 20, 2010 | 04:39 PM
BlackJackSS's Avatar
just buy the stuff yourself man!
takes no time at all. all you need it a jack and jack stands, ratchet, extention, 3/8th wobble, special socket, 15mm, and oil catch can. boom your done in 10-15 min.
Old Jul 20, 2010 | 04:44 PM
Camaro33's Avatar
yeah man do it yourself. all you'll need is (if I recall correctly) a 10 mm wrench for the oil drain bolt under the oil pan, and a 1.25" socket for removing the oil filter canister. A jack is needed to get under the car.
If you don't have a socket that size, just go to an autozone or something and ask to borrow one and change the oil filter there right before, during or after your oil change. that's what I did the first time when I didn't have anything over an inch. I've changed the oil 4 times in my balt since I've had it 2 years ago and I must say it's pretty damn easy and takes 15-20 minutes.
When you're done, don't forget to reset your oil life percentage on your DIC. Do this by turning the key but not starting the car (to ACC) and slowly depressing the gas pedal all the way to the floor three times in a row, then turn the key off.
That's everything and anything you need to know for an oil change. Oh, and use synthetic No napa crap.
Old Jul 20, 2010 | 11:29 PM
Rob9_ss's Avatar
thanks everyone! got it done just a minute ago. thanks ss.net members
Old Jul 21, 2010 | 03:05 AM
Dainslaif's Avatar
Just be sure you put enough oil in. Ours are about 6.5 quarts, while the 2.2/2.4 engine is 5.
Old Jul 21, 2010 | 03:19 AM
Diaz1488's Avatar
hehe
I work at the walmart automotive.. I use mobil one 5w30 extended performance.. but the crappy fram filters idk about them =/ I do my own oil changes at special price...
I put 6 quarts exactly.. adding the .5 quart is gonna make a difference ?..
Old Jul 21, 2010 | 10:51 AM
Karlen89's Avatar
I usually put 6 qts.
Old Jul 21, 2010 | 11:02 AM
coopercharge's Avatar
I dont know where you get 60 but I get my mobil one 5 quarts for 26 bucks and my K and N oil filter for 12 buck 60 sounds a little steep. I have only spent that much when I use royal purple in the summer due to racing!
Last edited by coopercharge; Jul 21, 2010 at 11:03 AM. Reason: Automerged Doublepost
Old Jul 21, 2010 | 11:23 AM
Dainslaif's Avatar
I'm pretty sure the manual calls for 7, which is why I only short it half a quart.
Old Jul 21, 2010 | 10:00 PM
xxxxsh4d0wxxxx's Avatar
I just got my SS/SC not too long ago, and I did an oil change, Mobil-1 Synthetic Extended Performance 5w-30.. Long story short, 6 quarts was a little over half on the dipstick.
6.25 was "full" for me. Will the .25 hurt if lack there of..? No.
Old Jul 21, 2010 | 11:44 PM
Dainslaif's Avatar
Meh, point being just make sure you're on the full line. I've heard way too many stories about people only putting 5qts in instead of the amount our engine needs.
Old Jul 21, 2010 | 11:49 PM
ericgt79's Avatar
i usually buy my own oil n filter and just have someone change it for me under close watchful eye cus i dont want my oil stolen or my car fucked up
Old Jul 21, 2010 | 11:53 PM
As long as the oil is within the 2 mark on the dipstick you are perfectly fine. 6.25 is what I always add. 7 quarts will be over filling it.
I would do the same thing if someone else changed my oil, but from experience I can tell you that its annoying as **** and makes you screw up more if someone is looking over your shoulder while your changing their oil lol.
Last edited by SSBlack06balt; Jul 21, 2010 at 11:53 PM. Reason: Automerged Doublepost
Old Jul 22, 2010 | 09:00 AM
Its not a very difficult procedure to change the oil I alway do it myself.
Old Jul 22, 2010 | 09:50 AM
ericgt79's Avatar
yea i do all my own work most i just dont change my oil cus im too lazy
Old Jul 22, 2010 | 10:18 AM
Staged07SS's Avatar
Administrator
Administrator
LSJ's vary from 6qts-6.5qts.
The manual states 6qts, mine has always needed 6.5qts.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
