Oil change?? questions
Old May 17, 2007 | 04:50 PM
LsJ2canada's Avatar
I was just reading some other threads.. wondering do guys out here wait until the oil change light comes on or what do u do?? what kinda oil are u running??
I personaly change my oil every 3500km usually about 60 % (is that it will read)
I have always wanted to change the oil from mob 1 what n e one else running??
WHAT DO U GUYS DO
Old May 17, 2007 | 04:55 PM
an0malous's Avatar
Mobil 1 all the way.
or at LEAST stick with a comparable full synthetic.
I change mine every 5k KM's
I pay absolutely no attention to the oil life meter.
Old May 17, 2007 | 05:04 PM
cmj917's Avatar
Oil changes every 3000 miles (~5000km) - the oil life monitor is usually about %60.
Always Mobil 1 Synthetic.
Frequent oil changes are the best preventive maintenance for an engine.
Old May 17, 2007 | 05:09 PM
rnjmur's Avatar
I use Mobil 1 and change the oil at about 30% usually. You are just going to start another oil change battle of informed vs. uninformed. When using sythetic oil you are wasting your money to change your oil every 3000 miles. Do some research on the matter - google is your friend...
This is not so true anymore. With regular oil; yes you should change your oil every 3,000 miles. With synthetic it really isn't necessary. Synthetic oil has been shown to actually protect your engine BETTER when it gets MORE then 3000 miles on it. Again, do some research on sythetic oil and oil changes. Make sure you look at independant research, because the research the oil companies do is going to be biased.
Old May 17, 2007 | 05:16 PM
sealy's Avatar
same as above. 3000miles and it's usually around 60%
i just got by miles though, keep it safe.
Old May 17, 2007 | 05:17 PM
an0malous's Avatar
Do you have any evidence showing that synthetic oil protects your engine better with more than 3k miles...
Im not disputing it. id just like to read it.
Old May 17, 2007 | 05:20 PM
blackngold20's Avatar
use the search
Old May 17, 2007 | 05:22 PM
an0malous's Avatar
I already did chief.
and the first few sites i read over said nothing about the oil getting BETTER as it got older...
only lots of sneaky little clauses about running your oil past 5k that everyone seems to ignore.
Old May 17, 2007 | 05:26 PM
that sucks...lol
Old May 17, 2007 | 05:41 PM
rnjmur's Avatar
I don't remember off the top of my head what site they were on. A really good site to check out though is bob is the oil guy he dispells alot of the fact and fiction of synthetic oil and oil changes. He even gets into regualr oil quite a bit. I just hope that you are up on your chemistry and physics because his site can be pretty technical... LOL...
Old May 17, 2007 | 07:10 PM
an0malous's Avatar
you should have a close read on that site.
took me 5 minutes to find posts full of bullshit.
and even a nice big post made by someone who OBVIOUSLY works for a certain oil company brand.
Im going to keep readin to see if theres anything useful over there, but that place looks to me nothing more than a forum full of peoples opinions.
nothing wrong with that, but hardly what i would call "independant research"
Old May 17, 2007 | 08:46 PM
06vrss's Avatar
I will only put Royal Purple in my car. I usually chage it around 30%.
Old May 25, 2007 | 01:35 AM
eurochevy's Avatar
you should change your synthetic just as often as regular oil ..synthetic is just overall better and yes it protects your engine BETTER when it gets more than 3000 miles on it because the oil particles that make up the actual oil are closer together than a conventional oil .. not to mention we supposed to take 5w 30..you can only get up to 10-30 which is the closest for conventional oil ..but its ok you can stick with your conventional or keep running your sythetic for like 10k km's or something haha ..we can compare crankshaft bearings when your engine needs to be rebuilt and im still goin strong
Old May 25, 2007 | 01:47 AM
Kaisoboy's Avatar
You are absolutly correct about the molecules being closer. You should change the oil synthetic or not every 3000 miles or 5000 km. the reason being that in synthetic oil it is not the oil properties that break down but the additives companies add to there particular brands. If you would like more information on this subject just visit the API (American Petrolium Institute) web site. There is alot of great information as they are a governing body.
Old May 25, 2007 | 01:51 AM
eurochevy's Avatar
sir..you are the man lol thnk u...and yes ppl when dealerships give it back to company's taking back the oil..all they do is clean it up and put in the additives again to return it to its lovely SM quality self so yes you are buying used oil haha
Old May 25, 2007 | 01:54 AM
Kaisoboy's Avatar
Thank you, Thank you...Bow Bow...and for my next trick.
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
roth
Sep 26, 2015 12:16 PM
