oil cooler
Old Oct 28, 2007 | 10:41 AM
silversccoupe's Avatar
oil cooler
Does anyone make an oil cooler-remote mount filter for the LSJ cars?
Old Oct 28, 2007 | 02:19 PM
Sharkey's Avatar
there is a way to do it. the gm sport compact build book tells you to cut the oil filter housing off the block with a saws-all, weld -10an fittings to the feed and reurn holes for, and use an off the shelf filter relocation kit. basicly doing it that way you would run it to the filter then to the oil cooler, back to the motor.
Old Oct 28, 2007 | 07:05 PM
That's a little more involved than I want to get but thanks.The factory cooler shares the system with the super charger so I'm trying to split the systems.
Old Oct 28, 2007 | 07:11 PM
Blurred Vision's Avatar
The superchargers are self contained, it dosn't use the engines oil.
Old Oct 28, 2007 | 07:23 PM
Yes I know,but the intake charge and the engine oil are cooled by the same coolant and heat exchanger.So not only does it have to cool the intake charge via the laminova,but also the engine oil via the factory oil cooler.
Old Oct 28, 2007 | 07:41 PM
No no no the intercooler coolant is completely seperate from the oil. The intercooler which is locater in ur intake manifold, has antifreeze that is store in ur heat exchanger pumped into it via the pump located under ur intake manifold then it travels up to ur overflow that is mounted on ur SC, then back to ur heat exchanger, never coming in contact with ur engine oil in any way.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
