Oil filter leaking
Oil filter leaking
Like the title says. Tried 3 different o rings and still does. Seems like its fine and ull see the ring start bulging out and start leaking. Anyone know why this would happen?
Thanks
Thanks
ac delco sells one that comes with the filter, cap, and oring.
http://www.crateenginedepot.com/stor...P1674C193.aspx
I dont see how the O ring could bulg out seeing that the O ring is seeted under the bottom side of the cap, unless the caps cracked or cross threaded.
My oil filter housing developed a crack due to poor casting and GM refused to warranty it. I had to pay out of pocket to have it welded.
I bet you have the same problem. There have been plenty of reports on here of porous blocks, only on ours the problem is on the outside.
u have the wrong oring, and or it is not in the correct groove. it doesnt go all the way to the top of the cap. there is a groove maybe 1/8th of an inch from the top that the oring rest in.
