Oil filter leaking
Old Oct 18, 2011 | 08:37 PM
troyss's Avatar
Oil filter leaking
Like the title says. Tried 3 different o rings and still does. Seems like its fine and ull see the ring start bulging out and start leaking. Anyone know why this would happen?
Thanks
Old Oct 18, 2011 | 08:41 PM
HyperMuffin's Avatar
Where you getting the O-rings from?
Old Oct 18, 2011 | 08:44 PM
troyss's Avatar
Autopart
1- mobile
1-fram
1-store brand
Old Oct 18, 2011 | 08:48 PM
Chevycobaltss3's Avatar
umm is there another oring on it, get a ac delco filter with the top peice and it should be good to go..!!!
Old Oct 18, 2011 | 08:55 PM
troyss's Avatar
Top piece? Ac delco soesnt come with ring
Old Oct 18, 2011 | 09:02 PM
evofire's Avatar
ac delco sells one that comes with the filter, cap, and oring.
http://www.crateenginedepot.com/stor...P1674C193.aspx
Old Oct 18, 2011 | 09:32 PM
troyss's Avatar
Sweet thanks
Old Oct 18, 2011 | 09:41 PM
07cobaltguy's Avatar
sounds like theres two orings on there dude.
Old Oct 18, 2011 | 09:42 PM
lol troy you better believe in me lol!!!
Old Oct 18, 2011 | 09:49 PM
CrateEngineDepot's Avatar
Only the Green O-ring on the cap would cause a leak unless the cap itself is cracked. Order the oilfilter with cap and you should be good to go.
Old Oct 18, 2011 | 09:51 PM
troyss's Avatar
I believe you James
Old Oct 18, 2011 | 09:52 PM
Just check and see if you have two o-rings on there noob. Unless you took an impact gun to your oil filter cap and cracked it lol.
Old Oct 18, 2011 | 09:58 PM
troyss's Avatar
Cmon now lol. Im not that dumb
The ring looks good and after leaving it running for a few min you can see it starting to bulg out
Old Oct 18, 2011 | 10:09 PM
Sunburst's Avatar
I dont see how the O ring could bulg out seeing that the O ring is seeted under the bottom side of the cap, unless the caps cracked or cross threaded.
Old Oct 19, 2011 | 02:57 AM
chris88z24's Avatar
My oil filter housing developed a crack due to poor casting and GM refused to warranty it. I had to pay out of pocket to have it welded.
I bet you have the same problem. There have been plenty of reports on here of porous blocks, only on ours the problem is on the outside.
Old Oct 19, 2011 | 01:06 PM
troyss's Avatar
Can you show me where Ill be looking for a crack at on housing?
Heres the bulging im talking about
Old Oct 19, 2011 | 01:11 PM
evofire's Avatar
u have the wrong oring, and or it is not in the correct groove. it doesnt go all the way to the top of the cap. there is a groove maybe 1/8th of an inch from the top that the oring rest in.
Old Oct 19, 2011 | 01:15 PM
troyss's Avatar
I tried 3 different O rings from diff companys.
I put it all the way flush as much it can go to top of the cap.
Old Oct 19, 2011 | 01:25 PM
evofire's Avatar
it does NOT go flush to the top....there is a groove about 1/8th down from the top of the cap.
Old Oct 19, 2011 | 01:28 PM
troyss's Avatar
But as you tighten it would it go to the top adventully?
Old Oct 19, 2011 | 01:29 PM
evofire's Avatar
then u for sure have the wrong oring.....buy the "kit" from crateengine depot and call it a day...check the filter housing and see if there is a oring stuck in there...
Old Oct 19, 2011 | 01:31 PM
troyss's Avatar
K thanks man
Old Oct 19, 2011 | 02:43 PM
troyss's Avatar
Had a friend look at it and he said it looks like its leKing from the oil sending unit
Old Oct 19, 2011 | 02:47 PM
68nova200's Avatar
are you torquing it down properly?
Old Oct 19, 2011 | 03:29 PM
Yeah looks like the wrong o-ring. Shouldn't stick out that much. Should go in one of the grooves near the top and stay there as you tighten the cap.
