oil pressure port
oil pressure port
I Just took off my intake manifold to do my dual pass. While I have it off, I have easy access to the oil feed ports on the front of the engine. However im afraid if I put my sensor on it, that it will have clearance issues with the intake manifold. Perhaps not though due to the LSJ Pheonalic Spacer that I'm installing as well.
Anyhow, I see this port under my oil filter. I want to know if that is ALSO an oil feed port that I can use for oil pressure. Circled in red is what I'm talknig about. The front side oil ports are circled in green.
I ended up useing the middle one circled in green, with a feed line to go to the sensor that I placed ontop of my supercharger shareing the bolt with that other sensor thats there.
