Oil Smells Like Gasoline
Old May 13, 2008 | 03:26 PM
Drakonen2000's Avatar
Originally Posted by rukkee
Hehhe i know , i was just letting the OP know that some of that stuff is normal. The white smoke would be a worry thou .
yes sir it would...i agree
Old May 14, 2008 | 01:03 AM
YellowBalt06's Avatar
what about the gas smell in the oil? will this make ur car loose power the white smoke and gas smell in the oil if its the piston rings? and what causes this to happen? sorry but im new to this whole thing
Old May 14, 2008 | 08:07 AM
ok, in your engine you have a piston inside of a sleeve that compresses the gas/air mix on the up stroke. A small ring on the piston seals it tight to the sleeve so you get compression at the top; when that ring is broken/grooved/ripped/etc. the seal is broken and the pressure created by the up stroke will push the gas/air mix past the seal and towards the crank. Since there is oil around the crank the gas/air mix will combine with the oil (since gas and oil do mix).
The reason for the white smoke is the oil slung up by the piston (to keep the sleeve walls lubricated) will get past the ring on the down stroke, and durrng combustion it will burn with whats left of the air/gas mix. When the oil burns it creates a white/blue smoke.
Causes for compression loss and ring failure are being rough on your engine for an extended period of time, adding boost (excess compression that the ring can not take), metal slivers in the oil, running the car hot.....normaly just beating on your motor
Old May 14, 2008 | 08:13 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Maybe your engine converted itself into a refinery! You could become a Billionaire with that car!
Old May 14, 2008 | 08:16 AM
car that makes gas FTW!!!!
Old May 14, 2008 | 10:01 AM
Saltbager's Avatar
I've been working for GM for a few years now and it seems like to me that higher performance cars sometimes get a gas smell in the oil. Be it a corvette or any SS model from time to time when you drain the oil there is a smell of gas and the cars all run great.
I checked for any Bulletins for you and I could't find any. But like everyone else told you, if there is any other color smoke than black coming out of the exhaust when the engine is hot, then you have a serious problem ..... probably rings
Old May 14, 2008 | 10:19 AM
vix9's Avatar
Yeah, there is definitely white smoke when the car is hot. Like I said before, the motor has about 3000 miles on it, and hasn't been beaten on at all. It's at the dealer now with a laundry list of warranty work...
Old May 14, 2008 | 10:24 AM
Saltbager's Avatar
Well good luck with that! Hopefully they will fix it right this time, right, LoL
Old May 14, 2008 | 10:31 AM
pimpnwink's Avatar
yea my car has the gas in the oil smell but i shrugged it off as teh car runs perfect knock on wood.
Old May 15, 2008 | 03:07 AM
welp took the car to the dealership..they say nothing wrong with my car...imagine that...so will i get a check engine light if the problem gets bad or what?
Old May 15, 2008 | 04:45 PM
  #36
Saltbager's Avatar
I'd beat the ***** off of it ..... then if there is really something wrong it will show up a lot faster ... just what I would personally do
Old May 15, 2008 | 04:46 PM
  #37
hmmmmm...well, thats one way.....or you could just pull out your wang, slap the dealer in the face with it, and tell them to try again!
Old May 15, 2008 | 07:13 PM
  #38
Saltbager's Avatar
LMFAO !
Old May 18, 2008 | 11:44 PM
  #39
vix9's Avatar
Quick Update...
White smoke is getting worse. Warm day today (upper 60's) and the car smoked constantly after start up for about 7 minutes. Also smoking whenever the engine is revved. Exhaust is sounding very different. Lots of pops, backfires, and just sounds more uneven than usual. Dealership said NOTHING was wrong lat week. I am having some trouble believing that. The engine is also starting to sound like it has a hell of a valve tick.
Can anybody give me some simple things to check so I can go in there and give them specifics?
Old May 19, 2008 | 12:02 AM
  #40
Man i have the same problem and the dealership said there was nothing wrong with it...i talked to a buddy of mine that has an 05 his oil smells like gas just like mine does...he said dont worry about anything because u will get a check engine light if its really an issue...
Old May 19, 2008 | 12:08 AM
  #41
vix9's Avatar
If it was just the oil, I might just not worry about it. It's all of the other things that make me nervous. Plus the fact that my car can't go a week without something else breaking. I shredded the timing chain guides in December and the car didn't give a CEL, but it was still severe enough to replace the motor. At any rate, the way it is running now, I have complete faith that a CEL is in my future.
Old May 19, 2008 | 12:14 AM
  #42
yeah thats what he said last night when we met up though...his is an 05 an mines an 06 same thing that his does mine does...hes done a complete rebuild with diamond piston and everything on his car so i think he knows enough to make me not worry plus were under warranty so if it happens take it on in for free...... i mean my exhaust pops and crackles i dont think you have anything to worry about personally
Old May 19, 2008 | 09:19 AM
  #43
vix9's Avatar
Another update...
Trying to figure out what's wrong. If I pop off the oil cap when the car is running there is lots of air being pushed out. Enough to make the oil cap dance if you just leave it sitting in there unscrewed.
Old May 19, 2008 | 09:21 AM
  #44
Another update...
thats because you are getting air past the rings and into the crank case...which would eventually come out the top of the motor...
...you have ring issues for sure man
Old May 19, 2008 | 09:24 AM
  #45
vix9's Avatar
I love my dealer. They gave me the car back on Friday and they are telling me there is nothing wrong with it.
Old May 19, 2008 | 09:25 AM
  #46
let us look back at post #37 ^^^^ ...do this
Old May 19, 2008 | 09:26 AM
  #47
vix9's Avatar
I've thought about it. Believe me.
Old May 19, 2008 | 09:27 AM
  #48
lol...its what i would do!!! but seriously...maybe you should try a different dealer?
Old May 19, 2008 | 09:43 AM
  #49
vix9's Avatar
The problem is this dealer did the motor replacement and GM "prefers" that I go there. It's all quite great.
Old May 19, 2008 | 09:44 AM
  #50
lol..quite....well, dealers suck!!!! they are wrong, just go up to them and say..."hey, you douchebags are wrong"
