ok i decided
ok i decided
I'm going turbo here. I need as much input from all the turbo swapped LSJ's out here. which kit and why not trying to spend 5 grand on the hahn kits
ZZP revised 316 stainless turbo manifold
Borg Warner turbo (your choice)
Turbo intake pipe with air filter
Turbo kit specific downpipe
complete Oil feed and Return lines
Charge pipes with all clamps and couplers
ZZP rotor ellimination plate
Cooler spark plugs
The ZZP kit is by IMO the best option. For $2g's you get the bare essentials. Spend another say $1g TOPS for a different intake mani/fmic and a few pieces of piping and there ya have it.
you can go custom for around 2 grand if you dont mind a used manifold. just make sure the turbo is either new or freshly rebuilt. i just did mine i think i spent about 3 grand total including a clutch and lightweight flywheel
My point is not that it's overpriced, cause it's worth $3k for that + fmic system. The point was that no matter what it's gonna cost alot more than the base price of the kit to set up properly
yeah i know it will cost more because i want to get the 1st suggestible upgraded turbo to hit least 400's. I wish i can find a used intake manifold or something
when you say that are you talking about the turbo aadapter plate they make?
no, your SC still stays on the car, just gutted with no rotors in there.
yeah i mean right now i'd be running a heat exchanger to cool my system instead of a intercooler like normal turbo setups. i wanna see how these rotor block off plates are and how hard they are to install
