Ok we got a problem
Old Mar 12, 2009 | 03:36 PM
TheSandMan's Avatar
Ok we got a problem
So im done with the installation of the stage 1 kit from ott and i thought i did everything correctly but now the car wont start. Seems like its doing the same thing its doing if i wasn't pushing the clutch in when turning the key. Do you guys think unplugged the battery will fix it and how long should i unplug it for? Or, what else may i have to do to get this thing running?
Old Mar 12, 2009 | 03:40 PM
ShortStack's Avatar
does the power turn on?
Did you put the fuel relay back in? (if you took it out).
Old Mar 12, 2009 | 03:41 PM
TheSandMan's Avatar
Yea power turns on, and i didnt take out the fuel relay. Its doing what it does as if the clutch is not being pressed in when trying to start our cars.
Old Mar 12, 2009 | 03:43 PM
ShortStack's Avatar
Try uplugging the battery for about 10 seconds.. see what happends...
is the PCM in correctly?
when u turn the key do you hear the fuel pump running?
Last edited by ShortStack; Mar 12, 2009 at 03:43 PM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 03:48 PM
TheSandMan's Avatar
Yea the fuel pump is running and i have the battery out now, its been out for about 10mins im going to try starting it real fast...(Praying)
Nothing i dont know what wrong with it, when i turn the key i hear the fuel pump turn on the lights and the radio turn on, then i press the clutch turn the key hear a click lights and radio turn off. When i turn the key back the lights and radio turn back on???
Last edited by TheSandMan; Mar 12, 2009 at 03:48 PM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 03:51 PM
Matt M's Avatar
Did you replace the ECM? Does their ECM require a relearn procedure?
Old Mar 12, 2009 | 03:52 PM
jasz71's Avatar
Hello Mr sandman, you might need to get a relearn from dealer.
Opps sorry matt m, you were quick to the draw...lol
Old Mar 12, 2009 | 03:54 PM
coopn8r's Avatar
Makes no sense O.o I've taken my pcm out a few times, never had any problems at all.
Old Mar 12, 2009 | 03:55 PM
TheSandMan's Avatar
Yea it does but i was told that i could start the car and drive it to the place to preform the relearn.
Old Mar 12, 2009 | 03:56 PM
rollingboostedss's Avatar
if that is the case then I'm glad I am send my pcm in first and getting that one back
Old Mar 12, 2009 | 03:57 PM
TheSandMan's Avatar
you think it might be the pcm?
Old Mar 12, 2009 | 04:01 PM
BlackSSNick's Avatar
probably a stupid point to make...probably.
but are all the connections in the engine bay....connected, and connected to where they should properly be?
Old Mar 12, 2009 | 04:02 PM
ShortStack's Avatar
could the engine not start if it notices an injector unclipped or something?
Old Mar 12, 2009 | 04:19 PM
TheSandMan's Avatar
i just checked everything and it all seems to be in place....
Does anyone know the answer to this... im taking them all out and re-installing them anyway but that keep the car from starting?
Last edited by TheSandMan; Mar 12, 2009 at 04:19 PM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 04:39 PM
Matt M's Avatar
That's a crank variation learn procedure. Without it, your car will still start and drive. Spark timing is just possibly off a little.
A seed key relearn or security relearn is not the same thing. Without it(If you need it.), you can not start your car.
Old Mar 12, 2009 | 04:44 PM
TheSandMan's Avatar
How do i know if i need one or not and how much will the dealer charge to do it on my car?
Also i dont think anyone else had a problem with there cars after installing the kit why mine?
Old Mar 12, 2009 | 04:46 PM
Black SS/SC 06's Avatar
you need a case relearn and security relearn
Old Mar 12, 2009 | 05:08 PM
TRANSAM197781's Avatar
no thats bs i got a different pcm and mine started just fine i would double check and make sure you didnt blow any fuses or something isnt accidently disconnected
how old is the battery
Last edited by TRANSAM197781; Mar 12, 2009 at 05:08 PM. Reason: Automerged Doublepost
Old Mar 12, 2009 | 05:11 PM
originaladrian's Avatar
check your fuses?
Old Mar 12, 2009 | 05:13 PM
TheSandMan's Avatar
I took it all apart and put it back together, batter isnt that old it should still be good... Im hoping its not the computer that i got from them...
Old Mar 12, 2009 | 05:18 PM
Eagle_f90's Avatar
Have you sent the old CPU in? If not try your old one just to see if it turns over. (if it does shut down fast)
Sunburst_SS's Avatar
is the theft light on???
If it is you'll have to do a theft learn......Attempt to start the car, then leave the key in the run position for about 10 minutes (until the security light goes out). Turn the key off, wait a few seconds, then to the run position again. Repeat that cycle a total of 3 times. After the 3rd time, key off wait a minute then start the car.
Old Mar 12, 2009 | 05:22 PM
TheSandMan's Avatar
Yes the light is on along with the check engine light im going to try that tho i really hope that fixes it.i have to leave it in the run pos. for ten mins each time?
Old Mar 12, 2009 | 05:24 PM
sick_ss/sc's Avatar
that sucks..i never had that problem
Old Mar 12, 2009 | 06:00 PM
TheSandMan's Avatar
If it is you'll have to do a theft learn......Attempt to start the car, then leave the key in the run position for about 10 minutes. Turn the key off, wait a few seconds, then to the run position again. Repeat that cycle a total of 3 times. After the 3rd time, key off wait a minute then start the car.
I ******* LOVE YOU******* rocks!!
