only 14 lbs with stage 2
well ive heard you can get 15
and i was only at 11 stock before i put it on but that was at like 1k miles
i heard that after your **** wears in you get more boost so i drove the **** out of my car to try and get the 1 extra psi and it hasnt came lol
im now at 3,300 miles lol
You had 11 stock now you have 14, it's perfect!
That sounds about right. Stage 2 wont make your car insane but it will give you a noticable safe improvment on both hp and torque. Im only running 15 to 15.5 depending on tempature. Im at sea level also, so it helps. Stock I was running 12 to 12.5.
Originally Posted by Cobalt Mav
do you guys have a 2.8 pulley?
im just wondering where my psi is first of all
and second of all what psi should i be running if i get a 2.8 or a 2.6
im only at 986 feet above sea level so seriously it shouldnt affect me 1 psi
so if i get the interceptor gauge it should read 15???
Originally Posted by FraGmE
only if your stock gauge isn't accurate. If its the elevation as mentioned above it should still read 14 psi
