only 14 lbs with stage 2
Old Sep 18, 2006 | 09:01 AM
CbYellowSS's Avatar
im only getting about 14 lbs of boost with stage 2 wtf???
Old Sep 18, 2006 | 09:09 AM
CTCOBALTSSS's Avatar
That's fine bro. You're right where you need to be.
Old Sep 18, 2006 | 09:11 AM
BLKSS's Avatar
what were you running before?
Old Sep 18, 2006 | 09:14 AM
CbYellowSS's Avatar
well ive heard you can get 15
and i was only at 11 stock before i put it on but that was at like 1k miles
i heard that after your **** wears in you get more boost so i drove the **** out of my car to try and get the 1 extra psi and it hasnt came lol
im now at 3,300 miles lol
Old Sep 18, 2006 | 09:18 AM
Yeah it's your elevation bro. I had 12 stock now I have 15psi.
You had 11 stock now you have 14, it's perfect!
Old Sep 18, 2006 | 09:20 AM
CTSSBowtie's Avatar
Ive got stg 2 and im running at 15. but elevation does play a part in it. at sea level...(me)...I went from like 10-11 stock to the 15 im pushin now.
BLKSS's Avatar
That sounds about right. Stage 2 wont make your car insane but it will give you a noticable safe improvment on both hp and torque. Im only running 15 to 15.5 depending on tempature. Im at sea level also, so it helps. Stock I was running 12 to 12.5.
Old Sep 18, 2006 | 09:25 AM
CbYellowSS's Avatar
im only at 986 feet above sea level so seriously it shouldnt affect me 1 psi
Old Sep 18, 2006 | 09:27 AM
Cobalt Mav's Avatar
do you guys have a 2.8 pulley?
Old Sep 18, 2006 | 09:45 AM
CbYellowSS's Avatar
no i have the 3 inch
im just wondering where my psi is first of all
and second of all what psi should i be running if i get a 2.8 or a 2.6
Old Sep 18, 2006 | 09:56 AM
CbYellowSS's Avatar
plus i have a injen cai so that should help the boost
if im only getting 14 how the hell do i get it fixed??
Old Sep 18, 2006 | 10:00 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I'm in ohio... about the same elevation... and mine is the same way. There have been some cold... none humid mights though that it has hit 15 instead of 14 though. It's all about the weather!
Old Sep 18, 2006 | 10:07 AM
CbYellowSS's Avatar
so how exactly does the weather affect it????
i hear how it does but what is the best weather for psi
Old Sep 18, 2006 | 11:10 AM
leviticus88's Avatar
your stock boost gauge maybe off by 1 psi, don't worry about it.
Old Sep 18, 2006 | 12:12 PM
CbYellowSS's Avatar
so if i get the interceptor gauge it should read 15???
Old Sep 18, 2006 | 12:14 PM
FraGmE's Avatar
only if your stock gauge isn't accurate. If its the elevation as mentioned above it should still read 14 psi
Old Sep 18, 2006 | 03:48 PM
CbYellowSS's Avatar
so 1k miles will affect me 1 psi.... that sucks lol
Old Sep 18, 2006 | 03:52 PM
05BlackCobaltSS's Avatar
Just to give you a heads up, my 12.5 PSI didn't hit until i had 6k miles on the car....just a thought.
Old Sep 18, 2006 | 08:53 PM
BCobaltSS's Avatar
I hit 15 psi at around 6-7grand but I have stage 1 with ZZ3.0 pulley and GMstage 2 belt and NGK spark plugs
turbochargedss2012
Sep 20, 2023 12:17 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
