option b, dualpass.
Old May 3, 2011 | 08:08 PM
T CUPP's Avatar
option b, dualpass.
I will be installing my stage3 zzp s/c kit tomorrow along with option b and dual pass.
I was wondering how you hook the option b up and the dual pass. I have used the search but nothing came up. can someone explain or give a detailed diagrahm
Old May 3, 2011 | 08:48 PM
Omnigear's Avatar
zzp website should have it or crate engine depot website.
395 plus's Avatar
good info from the ZZP website shows the routing if you need more than that go to Crateenginedepot.com and find the option b kit instructions.
Old May 3, 2011 | 09:02 PM
paddock's Avatar
If you PM me you email addy, I can send you the GM instructions...
But as far as plumbing the system goes, follow the ZZP diagrams, and you'll be good to go!
Old May 3, 2011 | 10:28 PM
T CUPP's Avatar
the only part i dont understand is the air bleed line that goes from the option b to stock heat exchanger....
http://i20.photobucket.com/albums/b2...2/diagram2.jpg
like does it need a T fitting to go into the hose that comes from th intercooler pump to the heat exchanger
Old May 4, 2011 | 11:30 AM
Special's Avatar
Once you get the hardware from ZZP, you will see a little brass fitting, shaped like an L. now, on the top left of your stock heat exchanger, you will see a little bolt, the only bolt on the top of anything up there!, that's where it goes, run the line from there, to the top inlet of your B tank
Old May 4, 2011 | 11:36 AM
07BoostedG5's Avatar
I dont sidebust people but god damn man searching is not hard.... Sorry to be rude.
BUT Everything below was found on this site....
READ Every question you could imagine will be answered here >>>>http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
Old May 4, 2011 | 11:43 AM
Omnigear's Avatar
if you cannot comprehend, have some1 that does around you. it will reduce the pain later on wondering or blaming zzp for the parts =p
Old May 4, 2011 | 12:28 PM
klloyd's Avatar
Deffinately use the color diagram. Its way easier then looking at the other one. The blue line will go out of the old heat exchanger and into the new one and out of that into the dual pass. I had to use a dermel to cut the clamps off of the oem h/e, I think GM glued them on. You shouldn't have any problems it just looks way more intimidating then it is.
Old May 5, 2011 | 03:48 PM
T CUPP's Avatar
okay since i have option b wll the filler neck that sits infront of the s/c be needed?
Old May 5, 2011 | 03:59 PM
redcobalt07's Avatar
no
Old May 5, 2011 | 04:40 PM
wtf read the link all the answers are there, you always want things spoon fed bro.
Again READ http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
