Option B help please
Old Jul 16, 2008 | 12:47 PM
burntorange's Avatar
Okay, after I have finally given up on waiting for the local performance shop's help on installing my dual pass and option b setup, and desperately need to return my core.... I have decided to try this myself. First, I can't even get the resevoir to fit, and next I cannot find a good how to with pictures and stuff.. Can anyone post up pics of the final project please and tips and tricks to help me out please? Just another desperate cobalt owner trying to be fast lol
And thanks to all for help and support.
Mike
Old Jul 16, 2008 | 01:06 PM
qwikredline's Avatar
Read the instructions with the kit. Make a bracket to hold the saturn ion reservoir bottle. I got this from the redline forum:
You have to take off the SC and intake manifold off. Take off the IC pump and you can get at bottom 2 bolts under the intake. They are a bitch! You can only turn those bolts a little at the time. You'll have to change around all the hoses that have anything to do with the intercooler (IC) system or whatever you wanna call it. So take off all the hoses as you take the car apart. I have a hoist in the shop I work at so that made it easy to get at all the hoses and stuff. So flip the 2 laminova cores (whatever ones the GM instructions say at http://www.crateenginedepot.com/store/pdfs/sidekit.pdf). Put the endplate on and put the intake and IC pump back on the car. Don't forget the bottom 2 intake bolts before the IC pump. haha
So asuming you already have the coolant bottle bolted in, and the 3/4" nipple on it pointing towards the front and towards the drivers side a bit. I ran the hose from the tank to the t-fitting down by where the SC pulley is. Make sure you tie the hose away from the belt and pulley good. Plan what stock hoses you're gonna reuse to make everthing line up right without kinks in the hoses. I started working from the dual pass endplate and out from there. You might have to cut sections out and use the straight and 90 degree 3/4" elbows to connect the hoses and lengthen them out. Watch out for the hose running from the coolant bottle to the t-fitting because it's kinda hard to run without interfering with the SC and belt. Just follow the GM instructions on the hoses. The pics I refered to which I printed are on page 5 and 6 at http://www.crateenginedepot.com/store/pdfs/sidekit.pdf. Just play around with all the hoses and make sure that you find out what one is best to use where before you start cutting them to make your connections. On page 6 where it points to the .040 orfice, thats what hooks to the top of the heat exchanger on the passenger side. you can look right in by where the hood latch it. I just used a wrench from there without taking off the plastic cover to get the pipe plug out. Thats where you screw the fitting in that takes 1/4" hose, the thread is 1/8"npt The orfice is the part you break off the t fitting shown on page 4 of the instructions.
So basically get the two, 3/4" T-fittings( thats what I used becasue everyhing seems to fall into place better.
-5 feet of 3/4" hose
-3 feet of 1/4" hose
-bunch of clamps for both sizes
-small t-fitting to make the orfice
-some angled metal to make the brackets
-the stock Ion Redline coolant bottle
-a bunch of 90degree and straight 3/4" connectors
Once you get everthing hooked up, fill up the coolant resivor and it will go down a bit. Put on the SC, belt and everthing else. Fill the resivor back up and start the car making sure there's no leaks. Let the car warm up and keep checking for leaks. Go for a drive and check it periodicly making sure it's not too low and no leaks.
Your done!
I think I covered everthing. It's actually easier to do than it sounds, believe me. I though it was gonna be way harder to do but like I said, everything lines up pretty good.
ALSO: youMUST HAVE A TORQUE WRENCH to tighten the inlet and the s/c fasteners, you will need the right allen socket 6mm and the torque specs are 16 ft. lbs for the intake manifold bolts and nuts; if you have removed the intake manifold studs to make removing the manifold easier, they are tightened to 44 INCH lbs NOT foot lbs.
THE PN 88958721 2 pass end plate bolts are tightened to 89 INCH lbs.. The super charger bolts tighten to 18 ft lbs.
hope this helps PM me for the bracket pictures you need to mount your reservoir and the Cobalt has no clearance for the return line as the S/C so while the S/C is off carefully hammer back the sheet metal in the front radiator tie bar so the hose can pass under and away from the S/C pulley
Hope this helps
Old Jul 16, 2008 | 01:12 PM
I noticed this in the how to's but was wondering if anyone has any pics of their brackets and fitment? And big thanks for informing me that I must make my own brackets.
Mike
oh, and mine didn't come with any instructions
Last edited by burntorange; Jul 16, 2008 at 01:12 PM. Reason: Automerged Doublepost
Old Jul 16, 2008 | 02:15 PM
Mike
PM me your email i will send you the instructions and a link to the bracket and pics of the install
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
