Option B with NO Dual Pass?
Old Aug 6, 2009 | 01:51 PM
shroogis's Avatar
Originally Posted by bulletpound
like i said b4 i was having the EXACT same problem as you till i got a dual pass and everything went back down to normal. i too have the ottp stg 1. and on a day with iat 55 my iat2s are 79-80 crusing at 80mph. and if i do pulls it doesnt go higher than 135 and quickly drops lol
Looks like I'm ordering a dual pass endplate!!
If I do a pull in 80* weather it will hit 160* by 80mph and then take 5 ******* minutes to drop back down to 30-40 above ambient at 50mph.
Old Aug 6, 2009 | 01:52 PM
Area47's Avatar
Rent me! per hour
you have a vacuum leak somewhere in line.
easy test. remove the bleeder from the stock h/e and put the oem plug back in it. the grab one of the lines after the t-fitting, and clamp down on it for 5 seconds. keep an eye on the tank and make sure it doesn't spill over with the cap off.
Old Aug 6, 2009 | 01:55 PM
shroogis's Avatar
I don't have the plug anymore, what if I just cap the barb on the end of the bleeder fitting then follow your instructions?
Old Aug 6, 2009 | 02:15 PM
Area47's Avatar
Rent me! per hour
that'll work too
Old Aug 6, 2009 | 02:54 PM
daythecountrydied21's Avatar
And I would hold off on the dual pass endplate never know when something better may come..
Old Aug 6, 2009 | 02:59 PM
shroogis's Avatar
Like meth?
Old Aug 6, 2009 | 03:07 PM
newp better
just figure out your problem and in i'd say probalby a month or so you'll see what I'm talking about.
Old Aug 7, 2009 | 06:49 PM
shroogis's Avatar
Well, just like bulletpound said, removing option B without a dual pass endplate did the trick. I plugged up the opt b bleeder hose with a screw (lost the original plug), installed the stock T fill neck and filled it/bled it.
Everything is working as it should now...I'm not sure why, but option B is a pain in the ass to get working correctly without a dual pass endplate..I'll use it when I get the endplate though!
Thanks everyone for the insight!
Old Aug 8, 2009 | 02:02 AM
bulletpound's Avatar
told ya so
Old Aug 8, 2009 | 05:41 PM
Area47's Avatar
Rent me! per hour
using the tank as a fill works much better than the stock t. the way the tank is set up. it is a constant bleed as well.
Old Aug 19, 2009 | 05:05 AM
  #36
EatonTVS07's Avatar
click
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
