Option b question
Old Mar 7, 2013 | 02:47 PM
bumm81890's Avatar
Option b question
I searched and it didn't return anything too relevant but how long should the system take to bleed with option b? I installed a dual pass a phenolic spacer and replaced the pump as well as a zzp s3 fmhe so the system was open for a while. The line is spitting air back into the option b tank and its frothy. This is how I installed the bleeder hose.
Any input is appreciated
Old Mar 10, 2013 | 12:37 PM
nhanson's Avatar
Its a constant bleed system. Just keep your tank full.
UNLESS you have a leak somewhere from the cores or endplate.
Old Mar 10, 2013 | 12:45 PM
TStone's Avatar
Put like a zip tie or 2 around the hose/barb fitting.. and just let your car idle for a couple minutes and it'll all bleed out. Shouldn't take too long.
Old Mar 10, 2013 | 05:32 PM
bumm81890's Avatar
Thanks it eventually bled out but it was taking longer than i thought it would.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
