ott stage 1 kit
ott stage 1 kit
so im looking at getting this im new to this so I have a couple questions.
1. should I remove the Remove Torque Management?
2. is there anything else I need to get with this kit?
Thanks
Thanks
Yes, remove tq management.
Heat exchanger is always nice.
And before you ask me what that is.. please.. just look it up.. There is a crap ton of info about them on here...
Last edited by ShortStack; May 28, 2009 at 05:14 PM. Reason: Automerged Doublepost
Its always good to have one, esp when you are looking at having a Tune sent thru the mail.
A wide band measures you air to fuel ratio... There is a certain limit within the air to fuel ratio that it should run and its always good to monitor this.
I think anyone who is going to be launching there car should buy the ottp rotated tranny mounts. Other then that the ottp stage 1 kit is amazing. If you have traction mods, remove any torque management/boost restrictions.
tq management was designed to give ur transmission a longer life.. mine was removed and i really didnt notice anything. but get a wideband, interceptor to read ur iat2's and short term fuel trim. id also get a larger front mount h/e and do the hatricstu mod. the interceptor gauge has saved my car about 5 times now.. my h/e pump is starting to clogg up and u cant tell this without the gauge i watched my iats hit 174 degrees and 160 crusing = bye bye cobalt. pulled over hit it with a hammer and its back to 87 degrees crusing 120 wot.
Sep 28, 2015 12:51 PM
