ottp?
Old Dec 25, 2010 | 07:40 PM
DEZZIE41's Avatar
ottp?
im plan on getting ottp stage 1 this week.. just wonderind if i should take tq control off and what should i get my rev limiter set to? also waht kinda number should i c?
Old Dec 25, 2010 | 07:45 PM
gwatson650's Avatar
I would take torque control off, and set the limiter to 7200.
Old Dec 25, 2010 | 07:46 PM
DEZZIE41's Avatar
whats does the tq control do cause i use this car in the winter lol...what kinda numbers should i c
Old Dec 25, 2010 | 07:48 PM
blk06cbltss's Avatar
with a canned tune you wont see the best of numbers. if you plan on ordering from ottp id say call them first and make sure they have it in stock. i have my rev set to 7250 right now and i love it
Old Dec 25, 2010 | 07:50 PM
DEZZIE41's Avatar
ya cause i was goign to send my pcm in ship via overnight and hope to get it all back within 2 days
Old Dec 25, 2010 | 07:53 PM
i know zzp will overnight it back to you if you overnight it to them. personaly id say go with zzp
Old Dec 25, 2010 | 07:54 PM
DEZZIE41's Avatar
there like 100.00 more then ottp
Old Dec 25, 2010 | 08:00 PM
gwatson650's Avatar
The torque control let's you get a little more power out right before redline i believe. When I talked to OTTP they recommended i remove it. I would call and make sure everything is in stock.
ecot3c inside's Avatar
Just set your rev limiter to 7100. Don't go past that IMO
Traction control off the track is barely noticeable. I can't tell, it's up to you.
Old Dec 25, 2010 | 08:01 PM
DEZZIE41's Avatar
i head good and bad about both companys who is best u think
Old Dec 25, 2010 | 08:02 PM
CoreySS07's Avatar
Ive ordered from both and never had trouble with ether
Old Dec 25, 2010 | 08:05 PM
DEZZIE41's Avatar
the zzp is 50.00 more then ottp..but dont they both give out same hp?
Old Dec 25, 2010 | 08:08 PM
dont worry about hp numbers til you have a custom tune. canned tunes dont run the best
Old Dec 25, 2010 | 08:34 PM
mrbelvedere's Avatar
tq control pulls timing under hard load conditions remove it these cars dont have traction control i would say your looking at around 250 to the wheels at most with an ottp canned tune and expect it to be rich
Old Dec 26, 2010 | 01:51 PM
06cobalt racer's Avatar
VERY rich. i mean like less then 10:1.
Old Dec 26, 2010 | 02:50 PM
srt-10's Avatar
Take the torque management off, it will give you abit more top end torque...otherwise, this is what your power will look like....
Old Dec 26, 2010 | 03:37 PM
DEZZIE41's Avatar
wow not much for the money im spending
Old Dec 26, 2010 | 04:11 PM
CanadianCobalt's Avatar
Why did you only spin it to 5750, looks like that thing had more power to make.
Joel
Old Dec 26, 2010 | 05:39 PM
srt-10's Avatar
Joel
The rev limit was actually set to higher, that was the torque management killing the power at 5750.
Josh@ottp
Sep 17, 2015 12:03 PM
Josh@ottp
Sep 8, 2015 10:18 AM
