ottp header
https://www.cobaltss.net/forums/dyno...n-come-233964/
read that thread first. I'd show you multiple threads and more than likely multiple results, but this is the only results we have of that header to date.
There's Literally NOTHING else to go off of. They didn't test it themselves. So what do you want me to do? I at least showed him the One and ONLY test we have. Sorry it's a negative result. Nothing I can do about it.
ZZP hasn't tested theres either except on Tim's 400hp redline and other things were changed at the same time also. Go bolt ZZPs up to a car that makes peak power at 6000rpm and see the outcome. I'm not saying go ZZP or OTTP, i'm just saying giving someone a test like that to say hey, heres what an OTTP header makes is misinformation. OP you will definatly see you're stuff faster from ZZP than OTTP. OTTP builds them as requested which takes 2 weeks. I just have an OTTP header because i got it for a pretty good deal from Frew. But i wouldn't say it's a bad header.
look ZZP and OTTP have excelent parts. ZZP is with out a doubt fast. OTTP is hand made to order. if you want it now ZZP. If you can wait OTTP. if you don't care whos cheaper. I know someone running the OTTP they loveit. DOn't know anyone running the ZZP tho so i can't say either way there, BUT it WILL get to you faster.
I have no experience with this though. I say you bolt on a MAN "header"... (The kind that comes with a T3 flange on it)
If there would have been a zzp thread, I would have posted it.
Fact: the only thread we have to date on either header is what I posted up. I'm not biasing toward either header. I've made no comments to persuade anyone either way.
z28addiction
Sep 28, 2015 12:03 AM
