OTTP Heat Exchanger (4th Version/Newest Version)
Old Jun 28, 2010 | 01:54 PM
Staged07SS's Avatar
Administrator
Administrator
I'm in the market for an additional heat exchanger, and have been looking into OTTP's newest offering. Their new heat exchanger is a radiator style core which replaces their 3rd versions bar & plate type core. Some info. I have gotten from Sean are as follows:
It uses a raditor style core (all fins not bar and plate).
The core is actually larger then zzp's as well
Core Dimensions
28"x7"x3.125"
Overall Dimensions
32"x7"x3.125"
This unit weighs 8.4 lbs vs 14.5 of the last unit.
End fittings are metal and welded to the unit itself (ZZP's are plastic).
Does anyone here have this new version yet, and if so how do they like it? Thanks guys!
Old Jun 28, 2010 | 01:58 PM
EcoTecDriver's Avatar
if the plug is still at the bottom, its still fail.
Old Jun 28, 2010 | 02:01 PM
Staged07SS's Avatar
Administrator
Administrator
You can always replace the plug on the bottom if you had to. I'm not lowered so it really wont cause a problem for me. I'm looking for info on how well it cools.
Old Jun 28, 2010 | 03:14 PM
Black2.0's Avatar
i have it and its pretty nice. i was told its about 30% more efficient and its a lot lighter. the only thing i didnt really like to much about it was the nozzle to drain it is directly on the bottom and is like 5 inches from the ground..but i havent had any problems with it rubbing, the handle to drain it was bent back and that little plastic strips saves it from hitting the ground.
Old Jun 28, 2010 | 03:16 PM
Staged07SS's Avatar
Administrator
Administrator
Thanks for the info !! Have you noticed a drop in IAT2's with it ?
How was the install ? Did you remove the bumper to install it ?
Old Jun 28, 2010 | 03:21 PM
Black2.0's Avatar
umm i havent checked out the IAT2's but the install literally took about 30 mins. bumper didnt come off. just took the plastic off under the hood so i could see down there better and those are just those clips. it fits tight but slides in with ease. ill take a picture for you if you would like but give me about 15 mins to get it taken and uploaded.
Old Jun 28, 2010 | 03:23 PM
Staged07SS's Avatar
Administrator
Administrator
Yeah, that would be nice .... Thanks
Old Jun 28, 2010 | 03:48 PM
Black2.0's Avatar
heres the shity pics the bugs beat it up
heres front view
http://i886.photobucket.com/albums/a...o/DSCN0553.jpg
heres the bottom i jusr discover the nozzle rubbed a hole through the plastic. i even bent it up so it wasnt lower. i drive my car very easy and its not lowered
http://i886.photobucket.com/albums/a...o/DSCN0552.jpg
heres a pic to show gap between bumper its tight but fit in easy. also shows the mount area a little bit
http://i886.photobucket.com/albums/a...o/DSCN0551.jpg
heres a pic to show gap between rad and new h/e like 3inches apart
http://i886.photobucket.com/albums/a...o/DSCN0555.jpg
its not really hard on the install might get a little coolant on you running the hoses. then you gotta keep filling it and driving it and filling it throughout the week to get all the coolant down in the new h/e. jack stands and taking off the plastic cover over top the radiator is all you really need to do it..
Old Jun 28, 2010 | 03:55 PM
xnigelx's Avatar
that picture with the valve is what i was looking for. That thing is pretty fail :/woulda been better on the side i think. at least its pluggable
Old Jun 28, 2010 | 04:02 PM
ei3dag3's Avatar
yup, jordans broke off after a little scrap.
Old Jun 28, 2010 | 04:03 PM
shroogis's Avatar
Just plug it. It doesn't drain for **** anyway. I believe it is 1/4" NPT (don't quote me on that)
Old Jun 28, 2010 | 04:17 PM
Staged07SS's Avatar
Administrator
Administrator
heres front view
Thanks man !!
I'll look into this. Thanks !
Last edited by Staged07SS; Jun 28, 2010 at 04:17 PM. Reason: Automerged Doublepost
Old Jun 28, 2010 | 04:20 PM
Supercharged Guy's Avatar
Yeah the drain on the bottom = fail I'm sorry
After a re-design they could'nt put it on the side
Old Jun 28, 2010 | 04:32 PM
Black SS/SC 06's Avatar
If you can mount it with the bumper on, make a how to because I want to know how you did it. Had to be magic
Old Jun 28, 2010 | 04:34 PM
shroogis's Avatar
I mounted my ZZP S2 on my Red Line with the bumper on.
Old Jun 28, 2010 | 04:35 PM
tanelk's Avatar
yea no kidding, you got to have hands of a 5 year old to install it with the bumper on
Old Jun 28, 2010 | 04:39 PM
Haha, I love the use of the word fail on this site .... (fail this fail that)
It's a friggin drain. You really don't need it .... Pluging the hole with a smaller fitting to avoid scraping is not "fail".
Your right "plugging the hole with a smaller fitting to avoid scrapping is not fail"
However re-designing a HE and not putting the drain plug IN the PROPER location = fail
Old Jun 28, 2010 | 04:50 PM
Staged07SS's Avatar
Administrator
Administrator
I dont even have it yet ....
I'm trying to see if anyone has it, and what they think about it.
By the way the 4th version is different than the one you have. Not saying it will fit better, because I have yet to buy one and install it
I agree with that.
Last edited by Staged07SS; Jun 28, 2010 at 04:50 PM. Reason: Automerged Doublepost
Old Jun 28, 2010 | 04:56 PM
I agree with that.
Yea I think I have the 3rd
Old Jun 28, 2010 | 09:55 PM
damien's Avatar
Yup, heard of this. Waiting for them to release it so I can scrap my unit that magically spurs leaks at the 2 sides.
Old Jun 28, 2010 | 10:28 PM
Rodimus_Prime's Avatar
can anyone confirm the bottom fitting size, im lowered and just ordered this im just going to plug it with a bolt
Old Jun 28, 2010 | 11:58 PM
Staged07SS's Avatar
Administrator
Administrator
When I get mine I'll let you know ....
Hopefully someone on here knows so I can get the correct size plug ahead of time.
Old Jun 29, 2010 | 12:15 AM
shadowfaxss's Avatar
I took the drain off of mine and put in a plug......just take the fitting off and go to Home Depot or Lowes.......you will find the size. Use the loctite thread sealer vs tape though.
This heat exchanger works wonderfully. IAT2s recover very quickly (even when in 100 octane mode). I don't know how anyone could properly and perfectly fit; also drill the holes to mount the HE without removing the bumper cover or front valance.
Old Jun 29, 2010 | 07:43 AM
joshcsepegi's Avatar
you fail no you fail no fail is fail wait i fail... haha
I fail in finding this price for this said item.. me need bigger cooling so my engine dont fail.. haha
rodimus don't make me fail how much was this?
Old Jun 29, 2010 | 08:00 AM
Staged07SS's Avatar
Administrator
Administrator
I will post pictures once I install this. Maybe a how to if I figure out an easy way to perform the install.
