Ottp stage 3 vs. Hahn turbo kit
Old May 6, 2010 | 02:31 PM
  #101
MP Cobalt's Avatar
I'm going TVS since I have all the cooling mods already for it and because i want to keep my torque numbers higher also. Any meth injection will work fine, meth is meth.
Old May 6, 2010 | 02:34 PM
  #102
krazycobalt's Avatar
Originally Posted by BlackSSNick
Yea I see what your saying, I am basically stock, no egine mods cept cai and I hooked hp tuners up to remove torque management and manipulate the o2 sensor so I could pass emissions
Yeah removing it on a stock engine is not a very big deal, but if you're planning on pushing up to 350WHP with OTTP stg.3 then you have a serious amount of power. Without TM you could have some problem (which I don't want)
Old May 6, 2010 | 02:35 PM
  #103
BlackSSNick's Avatar
When I go to install my h/e and option b tank, should I just buy a dual pass and do all that at one time while I have it all apart?
Also how hard is it to install a dual pass?
Old May 6, 2010 | 02:40 PM
  #104
Well you need to take off the S/C to install a dual pass and if you are going to all the work to get 350WHP and doing an OTTP stg.3 kit and don't instal dual pass... well your dumb! So YES you should have one and any monkey with a wrench can install one!
Old May 6, 2010 | 02:41 PM
  #105
MP Cobalt's Avatar
I would do everything at once. like the h/e, dual pass, and opt b
Old May 6, 2010 | 02:47 PM
  #106
That is the way that it is done!
Old May 6, 2010 | 02:50 PM
  #107
So starting with a h/e, opt b, and dual pass, I should have enough cooling at that point for the tvs?
Old May 6, 2010 | 02:58 PM
  #108
From what I have heard yes! This is what I am planning on doing primarily and then adding meth! With a H/E, dual pass and option B you should be safe with either a stock pulley or 3" pulley for sure!
Old May 6, 2010 | 03:33 PM
  #109
I think this is what I am gonna do, ottp stage 3 with ottp h/e, opt b tank, and dual pass, and get it tuned fairly safe, then after a little while install a meth kit and tune it more.
At this point my questions are a little off thread topic but how to the meth kits work? Do they constantly spray when the car is running or only when you hit the gas pedal?
Old May 6, 2010 | 03:38 PM
  #110
Bl4des's Avatar
it come on at a set psi
  #111
Brenticus's Avatar
hahn is more expensive with lesser powerband and more extensive install. ottp stage 3 is an easier install with i higher powerband and is also cheaper. honestly though, i have to say that as a fan of both, you'll most likely be more likely to reach more with the hahn and be more satisfied with their services. not a bash to ottp, i like them a lot.
Old May 6, 2010 | 03:39 PM
  #112
rico's Avatar
Originally Posted by Studmuffin02
Hahn stage V kit is the way to go or thats what i am planning on doing and its gunna be all sex.
-Stage V from Hahn
- HP tune (only at 15psi)
- Wot box
- 80lbers
- Hahn 3" catback
- dual aeroforce guages
- stage 2 axles
i need statge 2 mounts, ottp rotated mounts and i guess hahn catback to be set on ur list
Old May 6, 2010 | 03:41 PM
  #113
How do you hook it up, wire it into the ecu?
Old May 6, 2010 | 03:42 PM
  #114
Bl4des's Avatar
you either use a boost line or tap the map sensor
Old May 6, 2010 | 03:44 PM
  #115
Oh ok I see
Old May 6, 2010 | 04:02 PM
  #116
csementuh's Avatar
Hmmm. I believe most everyone with extensive mods has torque management removed... Can you cite any sources that say TM is good or bad with power? Rotated mounts, upgraded suspension, axles, etc, should save you unless you totally break your tranny. I would believe that TM would be shooing yourself in the foot though with any setup really, as it would cut power when you needed it during a race or whatever.
  #117
BlackSSNick... If you are planning on this set-up I would suggest 3" intake, LS4 Throttle body, and stg.2 rotated mounts
Old May 6, 2010 | 04:14 PM
  #118
Is ottps cai 3"? Because you can get a bung for meth nozzle which will be perfect
Old May 6, 2010 | 04:18 PM
  #119
You betcha buddy! You will have to go to an auto wreckers to find an LS4 TB:
Here is the list of vehicles you can get one from:
3.5L colorado 04-05
3.5L envoy 05
4.2L trailblazer 03-05
4.2L hummer h3 06
4.2L bravada 03-04
4.2L envoy xl 03-05
4.2L envoy 03-04
4.2L impala 06
5.3L isuzu ascender 03-05
05-06 trailblazer ext
4.2L canyon 04-05
3.5L monte carlo 06
5.3L trailblazer 06
4.2L rainier 04-05
4.2L sab 9-7x 05-06
5.3L envoy xuv 03-05
Old May 6, 2010 | 04:24 PM
  #120
csementuh's Avatar
ZZP sells the LS4 TB's too for $99.99
Old May 6, 2010 | 04:26 PM
  #121
Yupp most people with a lot of mods remove it... There are dangers for sure! I looked for the thread, but couldn't find it. If I do, I will send it to you! I also chatted with some of the local tuners and they said it is personal choice! Removing it will give you more hp, toque, better and faster shifts, but it comes with a danger
Didn't know that! Good to know... (Do you have link?) I know a guy that works at the local shop so he just pulled on for me and I got it for free
Last edited by krazycobalt; May 6, 2010 at 04:29 PM. Reason: Automerged Doublepost
Old May 6, 2010 | 04:43 PM
  #122
Do i really need an ls4 throttle body? It just gives improved throttle response forrect...is that the only benefit?
Old May 6, 2010 | 04:46 PM
  #123
rico's Avatar
blah ls4 tb and stock one. ahh i can see the argument starting all over again
  #124
It is bigger than what you are running stock and give you better response and if your going with a 3" intake I would suggest the bigger TB...
Old May 6, 2010 | 04:49 PM
  #125
Alright, makes sense
