out of luck..
Old Dec 24, 2009 | 02:01 PM
Rob9_ss's Avatar
out of luck..
so ive been needing a full mobil 1 synthetic change for quite some time.. i was told that i need a mechanic to change it because of the positioning of the supercharger is right over the oil filter and would need some special tool or to remove some parts from the charger... any one know of a place that will do this kind of work if any one knows what i am talking about.. lot of help, thanks.
Old Dec 24, 2009 | 02:04 PM
slowswap's Avatar
All they need is a 12" extension and a 22 mm socket I believe it is.
Don't quote me on the socket size.
Old Dec 24, 2009 | 02:09 PM
JohnnySasakiMGS's Avatar
Uhh. One of these http://www.amazon.com/Lisle-14700-Fi.../dp/B0009OMYAQ and a 10" socket extention. What a ******* mechanic. You can get just a regular socket that will fit but the special sockets that are made specifically for the ecotec oil cap are much shorter and are easier to work with in the cramped area under the blower.
Old Dec 24, 2009 | 02:13 PM
ssyellow's Avatar
yup quite easy to do once you get all the parts. about a minute or less of moving it around and the filters out.
Old Dec 24, 2009 | 02:15 PM
InfraRedline's Avatar
Its really easy to get the filter out. Just an extension and a 1 1/4" socket and your good to go. Remove the two bolts that holds the filler cap in and move it forward and pull the filter out that gap.
Old Dec 24, 2009 | 02:16 PM
ddsscobalt's Avatar
i just had the experience of a lifetime doing my oil change this morning.. its my third time doing it so you think i would have it down pat.. worst part is i work at a shop so i have all the tools necessary... I hot the socket tool stuck in the crevice to the left of the filter... I then got my extendable magnet stuck trying to push it back out from the other side, since my tool is aluminum and not magnetic.. 2.5 hours and alot of swearing today for my oil change... FML.... whatever you do, get anything that is magnetic so you arent a ******* like myself
Old Dec 24, 2009 | 02:23 PM
rukkee's Avatar
All i used to do was unclip one sensor and use a 12'' extension with a regular 1"1/4 socket . I would clean the area with a paper towel and then slide the filter out the side, under the blower towards the front....you have to wiggle it a bit but it comes right out the front . It really isn't bad if you don't let it intimidate you to start with ....and suprisingly not all that messy.
Old Dec 24, 2009 | 02:26 PM
Snakes709's Avatar
Im glad i got skinny arms....used a socket and extention, loosend it off and pulled it out....ill admit, doing oil changes on this car sucks. So ******* easy on my Z, pop the cover off, with your hands u can take off the oil filter and use a socket set to take off the drain plug, takes less then 10mins from start to finish.
Old Dec 26, 2009 | 02:04 AM
Rob9_ss's Avatar
hey thanks everyone! hopefully when i get time i will have to do it myself..first on this car..
Old Dec 26, 2009 | 11:48 AM
ssyellow's Avatar
You should have no problems. If a 16 year old can do it you can to. Just take it slow the first time.
Old Dec 26, 2009 | 11:51 AM
slowswap's Avatar
That's what she said!
Old Dec 26, 2009 | 11:59 AM
ssyellow's Avatar
ahh yes the mature nature of this site amazes me every time.
Old Dec 26, 2009 | 12:17 PM
slowswap's Avatar
The internet has never been serious.
turbosmart4
Aug 2, 2013 08:11 PM
:ninja:
Jul 18, 2013 08:00 AM
Fishers24
May 6, 2013 06:38 PM
intel
Nov 20, 2012 03:01 AM
