Outside Temp sensor
Outside Temp sensor
Where is the outside temp sensor located on our cars. I had the front end ripped apart all winter to turbo it and now i got a 2 pin wire connector going to no where. Its green and around the drivers fender side of the car. Im pretty sure its for the outside temp sensor that displays on the dash of the car. Only problem is I cant find the damn sensor, where is it located????
thanks man, I knew it was around there just couldnt find it. How much PSI were you running daily on your car?? Im up to 16psi now and I want to turn it up but just cant afford to blow it up right now LOL. The turbo im using is a GT2871
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
