Over heating problem need help asap
Old Aug 18, 2009 | 08:52 PM
Winkdogydog101's Avatar
ok so yesterday i was installing my halos and cut out the bottom plastic wheel well so my cai could breath. but car coolant temp was only like 182 highest usually only went up like one or 2
TODAY i went up to 198 and have no clue why its high now
also is there anyway how to remove the front right fender i didnt see a how to
Old Aug 18, 2009 | 09:56 PM
Maven's Avatar
First of all, 198 is not over heating by any stretch of the imagination.
Second if you removed plastic from the underside of the car its highly possible you disrupted the cooling of the car.
Old Aug 18, 2009 | 10:25 PM
ok
ok but it went up fast and its never been that high i dont see cutting out a small thing doing this is this 100%
Old Aug 18, 2009 | 10:36 PM
Brian MP5T's Avatar
Yes, the plastic creates airflow..
Old Aug 18, 2009 | 10:52 PM
but thats what causing it?
Old Aug 18, 2009 | 11:04 PM
Dead Zen's Avatar
zomg. 16 degrees? dude. maybe its hotter today? but yeah. plastic is there for a reason
Old Aug 18, 2009 | 11:26 PM
it was a bit hotter its about 108 down here but what degree should i worry about it getting too
Old Aug 18, 2009 | 11:31 PM
rnjmur's Avatar
If it goes over 240F then you have a problem.
You shouldn't have removed that plastic. It is there to channel air into the intake. By removing it you have made less air available for the SC to pull.
Old Aug 18, 2009 | 11:38 PM
no stuff
no i didnt remove the whole thing just the part under the cold air intake ive seen a ton of people on here do it and it makes the car screem
Old Aug 18, 2009 | 11:39 PM
Brian MP5T's Avatar
that's it...
Your car is FUCKED now that the plastic is gone...
Old Aug 19, 2009 | 12:06 AM
rnjmur's Avatar
Just because it makes more noise does not always mean it is better for the car. Everything is give and take.
Originally Posted by Brian MP5T
that's it...
Sarcasm = We will point him in the direction of your shoulder when the motor hydro-locks.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
