downpipe question
downpipe question
im looking into getting a catless downpipe pretty soon. i was just wondering what to do about the 2nd o2 sensor. how do i trick it? thanks
anyone?
anyone?
Last edited by thesteed46; Jul 22, 2009 at 08:35 PM. Reason: Automerged Doublepost
dont mean to thread jack Im also wondering about this because I plan on getting a wideband and won't be tuned for a while. will this cause the car not to run If i replace the 2nd o2 with the wideband? and is it to far from the header to be accurate?
The 05/06's you can go catless and just do a rear O2 sensor delete. It's true with the LSJ's so my assumption is you can do it with any other model as well. As for the 07's, you have to have a second O2 bung welded in to use a wideband. Because of all the emissions bullshit you can't do a rear O2 sensor delete like with the 05/06's.
No, you have to go in through HPT and delete the rear O2 sensor code, then unplug the sensor and take it out. I am running my Wideband through that bung, that's why I deleted the rear O2. If you aren't going to get a wideband, just leave the rear O2 sensor in. I had no codes from it.
get a o2 sensor extension, you can get them on e-bay, make sure it has a 90 degree bend in it so it fits. It stops alot of the flow to the O2 sensor so it doesn't read as much so you can go catless and have no check engine light. It worked for me
