downpipe question
Old Jul 22, 2009 | 08:35 PM
thesteed46's Avatar
downpipe question
im looking into getting a catless downpipe pretty soon. i was just wondering what to do about the 2nd o2 sensor. how do i trick it? thanks
anyone?
Last edited by thesteed46; Jul 22, 2009 at 08:35 PM. Reason: Automerged Doublepost
Old Jul 23, 2009 | 12:16 AM
RednBlack's Avatar
dont mean to thread jack Im also wondering about this because I plan on getting a wideband and won't be tuned for a while. will this cause the car not to run If i replace the 2nd o2 with the wideband? and is it to far from the header to be accurate?
Old Jul 23, 2009 | 12:18 AM
G85 SS's Avatar
The 05/06's you can go catless and just do a rear O2 sensor delete. It's true with the LSJ's so my assumption is you can do it with any other model as well. As for the 07's, you have to have a second O2 bung welded in to use a wideband. Because of all the emissions bullshit you can't do a rear O2 sensor delete like with the 05/06's.
Old Jul 23, 2009 | 06:43 AM
thesteed46's Avatar
so i would just leave it off?? cause there's a hole for it. could i leave it in and just unplug it?
Old Jul 23, 2009 | 08:25 AM
G85 SS's Avatar
No, you have to go in through HPT and delete the rear O2 sensor code, then unplug the sensor and take it out. I am running my Wideband through that bung, that's why I deleted the rear O2. If you aren't going to get a wideband, just leave the rear O2 sensor in. I had no codes from it.
Old Jul 23, 2009 | 07:02 PM
thesteed46's Avatar
alright, i'll give it a try, thanks
Old Jul 24, 2009 | 07:49 AM
inmymemory's Avatar
get a o2 sensor extension, you can get them on e-bay, make sure it has a 90 degree bend in it so it fits. It stops alot of the flow to the O2 sensor so it doesn't read as much so you can go catless and have no check engine light. It worked for me
Old Jul 24, 2009 | 07:54 AM
Staged07SS's Avatar
Administrator
Administrator
false .... i own an 07' and i used to have a catless downpipe along with a highflow downpipe and used an angled cel eliminator on it and it never once threw the P420 code. this may not work on all 07's so im not totally calling you, but it worked on mine
Old Jul 24, 2009 | 09:13 AM
G85 SS's Avatar
I'm talking about deleting the rear O2 sensor all together. It's my understanding that the rear O2 sensor can not be deleted on the 07's. That's what I was getting at.
Old Jul 24, 2009 | 02:47 PM
XTC_916's Avatar
Does a Magna flow high flow cat throw off a cel???
Old Jul 24, 2009 | 03:01 PM
G85 SS's Avatar
it varies. some cars get a cel, some do not. I have never gotten a code from high flow or catless. Brand is irrelevent.
Old Jul 24, 2009 | 06:26 PM
Staged07SS's Avatar
Administrator
Administrator
got ya .... i think you are right about that.
Old Aug 14, 2009 | 03:28 PM
Khase's Avatar
I'm about to install a ZZP downpipe on my 07, will I be able to use the downpipe bung for a wideband or will I have to get another welded?
Old Aug 14, 2009 | 05:33 PM
G85 SS's Avatar
Is it catted or catless?
Old Aug 15, 2009 | 04:04 AM
Khase's Avatar
catted
Old Aug 15, 2009 | 12:25 PM
G85 SS's Avatar
catted
Ok, so your downpipe has 1 bung in it right now. After the cat. If you delete your rear O2 sensor and put in a wideband, your readings will be lean because of the cat. So, you will have to get a separate bung welded in prior to the cat for your wideband.
Old Aug 17, 2009 | 12:36 PM
Khase's Avatar
Thats what I kinda figured. Thanks!
Old Aug 17, 2009 | 03:54 PM
G85 SS's Avatar
No problem.
Old Aug 19, 2009 | 03:21 AM
harryresh's Avatar
WHY WOULDNT THE 2ND o2 SENSOR BE ABLE TO BE ELIMINATED? IF IT DOESNT THROW AN ENGINE LIGHT AFTER THE COMPUTER DELETE U SHOULD B FINE.
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
