overboost problems
Old Oct 21, 2009 | 07:34 AM
Shawn08112's Avatar
overboost problems
got the car checked out last week about an exhaust rattle and overboost. got the car back with the mechanic telling me there was nothign wrong with it.
The overboost seems to be getting worst. everything is bone stock. Im reachign in the area of 15+ psi and now im hitting the safety actuator. Any other idea's as the cause? i still think its the cat
Old Oct 21, 2009 | 07:40 AM
06blackg85ss's Avatar
it's the cat
Old Oct 21, 2009 | 10:23 AM
ShortStack's Avatar
Originally Posted by 06blackg85ss
it's the cat
100%.
Old Oct 21, 2009 | 10:49 AM
Littlegoose's Avatar
agreed, mine's having the same problem. it's the cat, getting mine cut out this week and not gonna run one.
Old Oct 21, 2009 | 11:07 AM
JHans5774's Avatar
I am currently fighting the dealer as well they say nothing wrong same problem they even supposedly took the downpipe of and looked at it and said everything was fine. But only put down 152 hp on the dyno at 20 psi on a stock pulley but supposedly nothing is wrong
Old Oct 21, 2009 | 11:11 AM
SprChrg4Life's Avatar
ooo ooo ooo! i have experience with this... good story too.
this is my 2nd OEM supercharged car, 1st being a 91 Ford Thuderbird SC. back in 2004, at around 120kmiles, the car had very high boost for a few days... i was concerned, it had no power, yet boost was high... my dad came for a ride with me, and thought it was odd too.
i got in the driver seat, and at my dad's request he said floor it and keep it floored... so i did, for about 4-5 seconds, no power then kapow!! black **** flew out the exhaust and the car sprang back to life
if your cat is clogged, just get on it good and hopefully you'll blow all the chunks of platinum and rhodium or whatever other metals our cats use right out.
EDIT: wait, what?! the deal says it's fine?? you're under warranty still then i assume? tell them that the car is highly unresponsive and that stock boost shouldn't be so high, indicating a restriction of flow. then take your car to a competent dealer
Old Oct 21, 2009 | 11:13 AM
ShortStack's Avatar
That is the most absolutley worst advice ever.
You do not want to floor it and wait 5 seconds to blow the cat out of the back... That is just plain out stupid. You do things the right way, as in having the cat removed and then replaced...
That is horribly stressful on the engine, and could create far more problems than just the cat being clogged..
That is just absurd.
Old Oct 21, 2009 | 01:11 PM
LOLLOLOLOLOLOLOLOL
that was some of the worse advice I've seen on here.
Old Oct 21, 2009 | 01:29 PM
InfraRedline's Avatar
I wouldnt followthat advice. My friend's brother had a grand prix gtp and he started to lose power, well he kept beating on it an it started on fire under the hood and burned to the damn ground. The cause...clogged cat. And the cat was till clogged after the fire lol
Old Oct 21, 2009 | 01:46 PM
JHans5774's Avatar
So should I just keep insisting on it being the cat?
Old Oct 21, 2009 | 02:40 PM
daythecountrydied21's Avatar
lmao yeah just floor the **** out of it try to stay in VTAKKKK for atlest 20 seconds.
no. just do it yourself it takes a jack and a few wrenches. take the dp off, o2 sensor out get a stick and a mask. rubberband a plastic bag to the end of the dp and beat the **** out of the cat until you can see through the whole thing.
next step order a highflow catted or catless dp and be happy.
i had the same thing. pegged 22lbs of boost on a 3.0 and got off of it and said the ******* sitting till it's fixed lol. it was the cat. clogged to hell.
i was going to use my warranty for what it is for but the dealer kept insisting that it was a result of underlying problems or some bullshit. i think he was trying to hint that my exhust valves were burnt. funny guy.
Old Oct 27, 2009 | 08:38 AM
Shawn08112's Avatar
Well got the service manager with me. car would easdily get to 15psi of boost. said it was normal. so im done arguing.
Old Oct 27, 2009 | 01:08 PM
Time to cut it out and weld on a test pipe
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
