Overbore Piston rings??
When you order diamonds through OTTP, they order them from Diamond, and then ship them to you from OTTP... So OTTP doesn't actually "have" them, but can get them. But why not just go straight to Diamond?
very doubtfull
[QUOTE=mrbelvedere;6921798]you need to get the bore checked before you just throw a set of rings in it the bore may be out of round and have to much taper in it and if that is the case a nre set of rings wont seal up very well and you will need a ring filer and feeler gauges to set the ring end gap good luck
Ill talk to the machine shop guy to see.
Will the LNF WISECO pistons 86.5mm work on my LSJ ?
with the mods in your sig, i would not be overboring that skinny sleeve in your 2007 LSJ motor. YOu need to get sleeved. Contact mrbelvedere (he posted in this thread), he sleeved my block with some really nice cromoly sleeves.
he has darton sleeves
We used to stock alot of diamond pistons, 15-20 sets. Now we only stock one or two because they dont sell as much. We are warehouse direct with diamond though, so if you want a better price contact us directly.
