overdrive crank pulleys
hi, i am after an overdrive crank pulley but cannot find a lace that sells them on ebay o zzp
does anyone else know where to buy one?
am also after a lightweight alternator pulley and a 2.8 SC pulley with pulley module if i can buy these all from the same place that would be awesome!
oh and a SC actuator!!
many thanks
many thanks
i know have the pulley and charger
just after a place to buy a lightweight alternator pulley 6 rib and a overdrive crank pulley 6 rib
ideally i want to buy from the same place to save on postage and import tax
many thanks
many thanks
I believe MRZ makes alternator pulleys, but I could be wrong.
edit: found it http://www.mrzperformance.com/en/par...ernator-pulley
Getting a un-balanced/un-dampned crank pulley ur risking damaging ur engine especially on a forced induction vehicle. Do not waste your money on any other pulley then the ati one. Or just leave the factory one on.trust me when I say this please.....but the big advantage of the udp on the crank is being able to run a larger pulley on ur supercharger and get more power w/o working the charger harder..its worth it imo
Are you that daft that you can't read the description on ZZP's website?
This is good advice. I would listen to it. Stock pulley or ATI is the only real choice.
Overdrive is recommended for supercharged applications. It will increase blower speed the same as dropping 1 pulley size so it's recommended to run a larger pulley on the blower than you normally would.
I ment overdrive pulley....and no, stay away from any other pulley other than the ati! It is not sort the risk, sown the money and get the ati piece or just leave the factory one....engines and f/I is what I kno so please listen to me
patooyee
Oct 1, 2015 01:07 PM
