overdrive crank pulleys
Old 11-17-2010, 10:57 AM
joe_589's Avatar
hi, i am after an overdrive crank pulley but cannot find a lace that sells them on ebay o zzp
does anyone else know where to buy one?
am also after a lightweight alternator pulley and a 2.8 SC pulley with pulley module if i can buy these all from the same place that would be awesome!
oh and a SC actuator!!
many thanks
Old 11-17-2010, 02:02 PM
joe_589's Avatar
i know have the pulley and charger
just after a place to buy a lightweight alternator pulley 6 rib and a overdrive crank pulley 6 rib
ideally i want to buy from the same place to save on postage and import tax
many thanks
Old 11-17-2010, 02:38 PM
Hockeyman's Avatar
I believe MRZ makes alternator pulleys, but I could be wrong.
edit: found it http://www.mrzperformance.com/en/par...ernator-pulley
Old 11-17-2010, 08:17 PM
joe_589's Avatar
Yeah I think they have stopped making the overdrive pulley
I take it not many people run them over here?
Old 11-17-2010, 08:22 PM
hungryhip-ccp's Avatar
https://zzperformance.com/cobalt_ion...1222&catid=143
Old 11-17-2010, 08:39 PM
bykryder83's Avatar
If u get a different crank pulley get the ati superdampner overdrive pulley that zzp sells...
Old 11-17-2010, 09:52 PM
joe_589's Avatar
Slightly expensive that one
Old 11-17-2010, 09:55 PM
its the only one unfortunately, it is worth the money though.
Old 11-17-2010, 10:47 PM
PenguinPIE's Avatar
cobalt addiction makes them as well
Old 11-17-2010, 11:13 PM
bringing's Avatar
what does the superdampner overdrive pulley do???
Old 11-18-2010, 06:38 AM
bykryder83's Avatar
Getting a un-balanced/un-dampned crank pulley ur risking damaging ur engine especially on a forced induction vehicle. Do not waste your money on any other pulley then the ati one. Or just leave the factory one on.trust me when I say this please.....but the big advantage of the udp on the crank is being able to run a larger pulley on ur supercharger and get more power w/o working the charger harder..its worth it imo
Old 11-18-2010, 06:48 AM
Rattlesnake Race Shop
USMCFieldMP's Avatar
Are you that daft that you can't read the description on ZZP's website?
Overdrive is recommended for supercharged applications. It will increase blower speed the same as dropping 1 pulley size so it's recommended to run a larger pulley on the blower than you normally would.
This is good advice. I would listen to it. Stock pulley or ATI is the only real choice.
Old 11-18-2010, 07:49 AM
joe_589's Avatar
hi, i will be getting the crank balanced anyway, so i imagine they will balance it with the crank pulley wheel on it aswell so surely this limits the risk?
Old 11-18-2010, 08:41 AM
bykryder83's Avatar
I ment overdrive pulley....and no, stay away from any other pulley other than the ati! It is not sort the risk, sown the money and get the ati piece or just leave the factory one....engines and f/I is what I kno so please listen to me
Old 11-18-2010, 02:26 PM
joe_589's Avatar
What benefits will it give me then? Worth the money in output?
Old 11-18-2010, 03:40 PM
bykryder83's Avatar
You can run a larger s/c pulley witch in turn means ull be working the s/c less and all in all its more power.
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
Stuff
10-01-2015 05:47 PM
patooyee
10-01-2015 01:07 PM
cw383
09-30-2015 12:41 AM
Quick Reply: overdrive crank pulleys
