View Poll Results: Mods when a P0068 occurred
Stock
0%
Stock, Air Box Mod
25.00%
Stage 2
0%
Stage 2, Intake
0%
Stage 2, Air Box Mod
0%
Stage 2, Air Box Mod, Smaller SC Pulley
25.00%
Stage 2, Intake, Smaller SC Pulley
50.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
P0068 Issue
Old Feb 14, 2011 | 04:12 AM
megaman311's Avatar
P0068 Issue
So, before I post a possible fix for this, I need to gather some data.
I also forgot to add, Stock, Intake. But I am pretty sure that is not going to be the problem. Please post if it is.
Old Mar 1, 2011 | 10:45 PM
DYNOair411's Avatar
just threw that code up, installed an injen CAI and all else is stock.... my car dropped down to running on 2 cyl and gave me that "reduced power", i pulled over turned car off then on and worked fine except for the MIL. got home and scanned it for the p0068 code. i started the car 5 hours later and MIL was gone...i'm gonna look into the problem sometime this week.
Old Mar 1, 2011 | 11:39 PM
mrbelvedere's Avatar
P0068 Throttle Body Airflow Performance ECM, PCM
mods might not be the problem
Old Mar 2, 2011 | 12:18 PM
megaman311's Avatar
unplug your battery for about 30 minutes. I found out that a simple few minutes is not good enough. You should be fine. The code is a correlation among your SC inlet, Mass air flow, Map, and barometric sensors.
Old Mar 2, 2011 | 10:42 PM
DYNOair411's Avatar
Yea im going to do that and clean the MAF aswell. im going to look and see if the throttle body is dirty...plus i found that my cat is shatttered haha thank you recall for going to be paying for that.
Old Mar 3, 2011 | 07:31 AM
selfinfliction's Avatar
when i replaced the oil with water.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
