P0103 MAF High Code
Old May 26, 2010 | 01:16 PM
DVSk8er's Avatar
P0103 MAF High Code
i recently turbo swapped my car. to a vulcan intake manifold with a precision 50 trim. I have custom intercooler piping with a 3" zzp maf tube. The car has been tuned but i keep getting the maf high code. I checked shopkey it says anything over 10,000hz for the maf frequency will cause the code. When i do a second gear pull by like 5,000 rpms i am around 10,700hz. And my maf lb/min is around 46 to 47. Now my question is what is casuing this problem. do i need to upgrade to a 3.5" maf tube. Is it possible i'm maxing out the maf sensor. Let me know what you guys think. Also I'm running 22psi.
guess no one has suggestions. i pulled this quote from black06g85 on hp tuners forum. i think my problem is i have 2.5" on the cold side then it jumps to 3" for the maf tube which is only 10 inches away from the throttle body
just look at my setup on ss/net.
you want the BOV on hot side, MAf on cold side at least 18 inches away from the TB and in a straight run of pipe to reduce turbulance.
Also cold side where maf is must be 3" all the way from the FMIC to the TB. This will keep you from running out of range on the maf.
Then just rescale from there using a commanded vs actual afr % histogram. works pretty well and it's not hard to do. But don't do WOT runs til you get it somewhate accurate in cruising first.
Old May 26, 2010 | 01:42 PM
SCcobaltSS's Avatar
It this affecting your performance?
You are getting this code because your stock MAF high freq limit is set to 11000 hz, above that it will throw a code, obviously. This is where you run out of cells in the tune. You can set the MAF to fail up to just over 16000 hz (I believe that is its limit). The tune should do last cell interpolation. Is this safe? IDK I have not gone that high. Someone else would need to chime in.
Old May 26, 2010 | 01:44 PM
DVSk8er's Avatar
yea the car breaks up around 5800rpms or somewhere around there. then it temporairly goes into limp mode then clears up. but i get this code constantly. i keep clearing it but it comes back pull after pull. its really pissing me off. i think i need to change my whole cold side around.
Old May 26, 2010 | 01:46 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you cold side should really be 3 inch from IC to the throttle body. set the MAF fail high to at least 14000Hz and turn off the codes and set them to "no error reported" your gonna be going past the last cell but it will be fine
**edited since i read how your cold side is set-up**
Old May 26, 2010 | 01:48 PM
DVSk8er's Avatar
yea i wish it was that easy. i dont have hp tuners. and i'm broke already spent 250 to get it tunned and it still runs like ****
Old May 26, 2010 | 01:49 PM
SCcobaltSS's Avatar
Explain breaks up.
go back to the tuner and tell them to fix it. If it is not running right it is their fault.
Last edited by SCcobaltSS; May 26, 2010 at 01:49 PM. Reason: Automerged Doublepost
DVSk8er's Avatar
Originally Posted by SCcobaltSS
Explain breaks up.
if i get on it in second or third it pulls then misses i'm assuming opens the wastegate like i let off the throttle.
BLAZIN07SS's Avatar
I'm too JDM for you
who tuned you? its a simple fix to change that stuff
Old May 26, 2010 | 01:53 PM
DVSk8er's Avatar
honestly i dont really want to say who tuned me i dont want to start **** cause some people say he's an awesome tuner and other people say he sucks. so i'll just say that anytime i go back he tries to charge me dyno time. and if its a simple fix i'll probably just leave it now till i get retuned by most likely byt
Old May 26, 2010 | 01:58 PM
SCcobaltSS's Avatar
Tell your tuner that the tune is not working right and he/she needs to fix it. You should not be charged for their mistake.
Old May 26, 2010 | 02:04 PM
DVSk8er's Avatar
yea i'll see what i can do. and if i get time to go back out there. its about an hour away from me
Old May 26, 2010 | 02:10 PM
BLAZIN07SS's Avatar
I'm too JDM for you
charging for dyno? its a 2 minute fix that doesn't even require the car to go on a dyno
Old May 26, 2010 | 02:12 PM
SCcobaltSS's Avatar
true.
Old May 26, 2010 | 02:14 PM
BLAZIN07SS's Avatar
I'm too JDM for you
dude i treat my customers so good when i tune them. i usually charge $150 to $200 depending on what i have to do. and later fixes are reasonable prices. nothing outrageous
Old May 26, 2010 | 02:22 PM
DVSk8er's Avatar
yea well shops like to make money. wish i would have went with byt originally from what i hear he's a great guy and doesnt charge for retunes or fixes
Old May 26, 2010 | 02:23 PM
SCcobaltSS's Avatar
And you would also not charge again if your tune is not performing. This tuner is which is BS.
Old May 26, 2010 | 02:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
of course not. i worked with one guy for three days getting his tune solid cause i was having issues doing it.
Old May 26, 2010 | 02:26 PM
DVSk8er's Avatar
well i cant do to much till i get my new clutch put in cause the stocker is slipping like crazy.
Old May 26, 2010 | 02:58 PM
SCcobaltSS's Avatar
I have done the same.
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
