P0171
Old Nov 3, 2011 | 12:41 AM
kdub1492's Avatar
Question P0171
Ok guys so here we go. I bought my car about 4 months ago, as soon as I got it, it started to throw a P0171. Car runs great and I haven't had any serious problems with it. Bought it from a guy, car ran good and there was no CEL. I'm guessing he cleared it before he sold it too me. All it has done to it is a Injen CAI. Iv'e been reading a few things about why I would be getting the lean in bank 1 code but can't come to a full understanding. A few people say it could be because of the CAI but then others say that has nothing to so with it. Should I try my O2 sensors? I was also reading about Changing out vacuum lines. If doing so where would I go to get vacuum lines for my car? Thanks for all the help!
Old Nov 3, 2011 | 12:47 AM
Josuizzle16's Avatar
autozone
Old Nov 3, 2011 | 12:52 AM
volsfan92's Avatar
Most likely its the CAI... Idk bout the vacuum lines
Old Nov 3, 2011 | 01:13 AM
outtamymind's Avatar
most likely cause is the CAI. least likely is your O2 sensors. see if you can find a stock air box and put that back in and i bet you the CEL doesn't come back.
Old Nov 3, 2011 | 08:46 AM
kdub1492's Avatar
Damn I was hoping it wasn't the CAI! lol I'm thinking about getting the OTTP 3in, but I will try the stock air box. Thanks guys!
Old Nov 3, 2011 | 11:23 AM
kdub1492's Avatar
Bump! Can use all the advice possible!
Old Nov 3, 2011 | 11:50 AM
start with putting the intake back to stock. CAI's are notorious for throwing a run lean code on our cars without either modifying the spark plug gap or tuning for it.
Old Nov 3, 2011 | 12:54 PM
mrbelvedere's Avatar
when you change the location of the maf it scews how the maf reads i wouldent worry to much about it it is and has been a common problem on these cars since they were new yhr only way to fix it is to tune it
Old Nov 3, 2011 | 01:53 PM
not true, adjusting the spark plug gap is a valid option as well. i did it on mine when i had just an intake and without a tune it put my trims back to being dead on
Old Nov 3, 2011 | 01:59 PM
yea i doubt that had anythig to do with it the trims and a lean code gm recognized the problem and put a fix for it their staged tunes
Old Nov 3, 2011 | 02:07 PM
kdub1492's Avatar
I just bought new plugs that I'm going to put in. What do you suggest the plugs to be gapped at?
Old Nov 3, 2011 | 02:12 PM
start with stock gap. and see if things change.
and a staged tune is differen't i'm talking about stock tunes. you can adjust the gap to modify how strong or weak a spark is as well as it determines how long the spark fires thus changing how much air is needed before everything ignites. the maf is only half of what your fuel trims needs to calculate in. it also takes into account your o2 sensor reading. so if you fix the air issue in the combustion chamber and its reading correctly on the exhaust side your fuel trims will even out regardless of what your maf is reading.
Old Nov 3, 2011 | 02:23 PM
kdub1492's Avatar
ok thanks alot man
Old Nov 3, 2011 | 02:27 PM
i would recommend stock gap and if you can get it tuned over playing with the gap but if you can't get tuned then play with the gap a little bit.
Old Nov 3, 2011 | 08:57 PM
06cobalt racer's Avatar
should you go with a bigger or smaller gap if it is lean?
Old Nov 3, 2011 | 09:03 PM
if its lean you should tighten it up a little bit, you don't want to do too much maybe 2 or 3 thousandth of an inch should clear it up. it does take some trial and error. took me about a month to get mine to a point that my car liked.
Old Nov 3, 2011 | 10:56 PM
kdub1492's Avatar
Thanks for asking this! lol I went out and got some Denso's that were pre gapped at .34. Hopefully that will work. I had autolites in it before took them out and they were at .41!
Old Nov 19, 2011 | 12:15 PM
BlkSS4dr's Avatar
UPDATE??? having the same problem here
Old Nov 19, 2011 | 12:21 PM
kdub1492's Avatar
Well I changed my plugs and I went to a stock intake and I'm still having the CEL so idk! lol Time to just zzp stage 2 and get a tune I suppose
Dustonian131
Sep 23, 2015 08:03 PM
The Punisher
Feb 11, 2008 07:13 PM
o3nisoaso3
Jan 22, 2008 05:15 PM
Vin
Jun 7, 2007 06:45 PM
c24na
Tuning
Feb 11, 2007 01:00 AM
