P02135 Tracking Down the Problem help
Old May 8, 2012 | 11:06 AM
FryLoch's Avatar
Car has been throwing P02135 for a few months now, I've been reading a lot on here, it is usually the TB and cables, I was also under the impression that it could be the gas pedal since it says pedal/throttle sensor.
Before I spend some money on this I want to make sure I buy the right thing the first time, is it possible to test which problem it really is?
It's not a big problem although is becoming more common, I just clear it off with my interceptor...
Old May 8, 2012 | 11:19 AM
1AJeremyD's Avatar
Probably would have to grab a multi-meter to test the ohms but the issue is trying to figure out on the throttle what plug is what. Best bet would be to eliminate the pedal first.
Old May 8, 2012 | 11:44 AM
FryLoch's Avatar
Did I mention I hate doing electrical work?
Old May 8, 2012 | 11:51 AM
1AJeremyD's Avatar
Ya I'm sorry lol. You would have to get also a print out of the readings depending upon the % of throttle applied. When does it the code happen? Is there a particular condition that makes the code pop up or is it just normal driving? Start up? Engine Temp? It might be possible to eliminate one piece by just some info.
Old May 8, 2012 | 11:54 AM
tpete763's Avatar
When my car was throwing this code (along with 2138 code), the ecu had to be replaced to fix the problem. The dealership replaced the TB, gas pedal, The wires to the TB, the wires to the gas pedal, and finally the computer and that's what finally fixed it.
Old May 9, 2012 | 03:03 PM
FryLoch's Avatar
So it being the pedal is not as likely?
Old May 9, 2012 | 03:09 PM
1AJeremyD's Avatar
I wouldn't really rule it out because its just a resistor like the throttle is and resistors can go bad. The ECM being bad would of course be the final answer if both the pedal and the throttle appear to be bad.
Like I said before is it just completely random or is there a particular thing that triggers it?
Old May 9, 2012 | 03:13 PM
FryLoch's Avatar
Well it's usually right after i pull out of my apartment complex after the car has been running for a bit it doesn't happen. although yesterday it kept coming back multliple times just driving around town.
Old May 9, 2012 | 03:19 PM
1AJeremyD's Avatar
So if the car is warmed up its fine but when it's cold there's an issue or is it an issue when it's warmed up and not when it's from a cold start?
Old May 9, 2012 | 03:41 PM
Jdam8139's Avatar
My car threw this code and went into limp mode every time. It ended up just needing a new TB, but I bought the pedal assembly anyway. If you need it I could sell it to you. I ordered it from RockAuto and when it got here I had already installed the TB and fixed the problem, so it hasn't even been taken out of the box
Old May 11, 2012 | 09:48 PM
FryLoch's Avatar
Replaced the pedal 2 days ago and it hasnt thrown the code since then. I think I fixed it
turbochargedss2012
Sep 20, 2023 12:17 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
