P0507 cleaned tb, maf and map
As the title states I had some issues going on and I fixed them and now I'm getting a P0507 code popping up and after I cleaned the TB and maf it went a way for a little bit then came back so I searched on the forums and saw that I need to clean the MAP so I did and it ran great until the code came back. After I reset it the car runs great until it comes back. I have a canned tune from PCMforLess and have always had their tune and never had problems. Mods are 60#s, 3" cai, 2.8 pulley, cobalt addiction heat exchanger, maddab header/ zzp downpipe combo. Could this be a tune issue? Or do I need to start replacing sensors (Maf, map, IACV)?
Possible causes
- Dirty throttle body (You just cleaned it)
- Electric throttle control actuator misadjusted or damaged
- Faulty Electric throttle control actuator
- Intake air leak
- Poor electrical connection to the Intake Air Control (IAC) valve
When you cleaned the TB did you spray fluid into it or did you soak a rag and clean it that way?
- Intake air leak
At this point I'm thinking it's the tune. I'm sending my PCM to zzp tomorrow and hopefully can expect it back next week. I hope that solves it because nothing else seems to be the problem
i was throwing the p0507 code before as well and would clear it and it would go away for a little bit then come back. I hope its not the throttle body but if so then Ill have to get a new one soon.
Also I think I had a vacuum leak the hoses were dry rotted and when I tried to even take them off they ripped so I just replaced them. When I get my ECU back I will be able to know more of whats going on.
Last edited by rouseySS/SC; Jun 12, 2012 at 03:27 PM. Reason: Automerged Doublepost
