e85 timing question
Old Jun 12, 2012 | 07:51 AM
Tjolley's Avatar
e85 timing question
ok i was told by a friend that the lsjs dont make much if any power over 25 degrees of timing....im at 31 with no kr and a iat2 of 150. its 102 out here in california now thats y its so high. can any of u e85 guys shed some more light on this i also have zzp long tube header catless dp. zzp 3" catback. and a ported and polished m62.
Old Jun 12, 2012 | 09:51 AM
ebristol's Avatar
Your friend is right.
A lot depends on how the timing table is shaped. If you can get to 25-26* of timing your golden. Anything more and you are just causing extra stress on the engine.
Where are you running that much timing?
Old Jun 12, 2012 | 10:31 AM
Tjolley's Avatar
Up top....28-31 and zero kr
Old Jun 12, 2012 | 10:34 AM
Omnigear's Avatar
wow thats high 27-28 is the highest i have seen on my table for timing while on e
who is tuning?
Old Jun 12, 2012 | 10:35 AM
N1ckateen's Avatar
up top 26* is the maximum you should go. mid range you can run lots more. I'm not 100% sure what i'm running mid range but i believe it's in the 40* range.
Old Jun 12, 2012 | 10:39 AM
Tjolley's Avatar
im tuning my self...i have no idle isues...cold.start is getting beter everyday...almost normal...and im getting like 22 mpg
Old Jun 12, 2012 | 11:11 AM
ebristol's Avatar
What is your AFR?
Old Jun 12, 2012 | 11:52 AM
Tjolley's Avatar
Originally Posted by ebristol
What is your AFR?
9.88
wideband reads like 14.5-14.9
Old Jun 12, 2012 | 12:07 PM
ebristol's Avatar
What is your AFR when you are running 31* at WOT? Can you post your timing table?
Old Jun 12, 2012 | 12:13 PM
startingline05's Avatar
Originally Posted by Tjolley
9.88
That's just normal driving right? What about at WOT?
Old Jun 12, 2012 | 12:18 PM
Tjolley's Avatar
i forget the actual number but 10.9-11.2 on my wb... I run nitrous that's why it's so rich...35 dry
Old Jun 12, 2012 | 01:01 PM
TStone's Avatar
oh lord
Old Jun 12, 2012 | 01:08 PM
Tjolley's Avatar
Originally Posted by TStone
oh lord
problem???
Old Jun 12, 2012 | 01:14 PM
Chevycobaltss3's Avatar
Yeah bro, I've tested all the timing I could but I lost top end tq along with some hp. The best I seen was between 25-27 depending on top end load ...
Old Jun 12, 2012 | 04:34 PM
Bika's Avatar
Fail Less.
Have fun beating the **** out of your bottom end.
Just because it isn't knocking doesn't mean you're making more power.
Old Jun 12, 2012 | 04:47 PM
Area47's Avatar
Rent me! per hour
27 is the max timing that is usable up top. on e85. other fuels vary.
afr is fine at wot.
euthanasia's Avatar
Truth
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Builttss
Oct 4, 2015 10:21 AM
roth
Sep 26, 2015 12:16 PM
