p1133 ?
Old Apr 26, 2009 | 12:17 AM
Bika's Avatar
Fail Less.
p1133 ?
got the P1133 code today. mods are CA V2 header, 3" ZZP dp with cat, 42#s, 3.1"
Been running that header for a couple months. Idle AFR has always been on the rich side, low 14:1 ish.
Do you guys think my primary o2 is shittin the bed?
Old Apr 26, 2009 | 11:30 AM
Bika's Avatar
Fail Less.
anyone?
Old Apr 26, 2009 | 06:09 PM
stonny9's Avatar
if that is the heated o2 sensor code then dont worry about it. It is a fairly common code. I had it and never experienced and problems. Was told it is because the sensor isnt heating up fast enough because the built in heater in the sensor is broken. needs to be at something like 600 deg F to work properly.
Old Apr 26, 2009 | 06:35 PM
Bika's Avatar
Fail Less.
I am just curious as to what causes it.
either:
1. soemthing went haywire in the sensor itself.
OR
2. the placement in the c/a header is causing it not to cycle properly.
I cleared the code and it hasnt come back, yet. i'll just hope it stays that way
Turbotoy
Sep 25, 2014 10:12 AM
ss-KING
Feb 28, 2010 10:50 PM
silentd
May 9, 2008 08:50 PM
stonny9
Apr 22, 2008 09:04 AM
2K5SS/SC?
Feb 23, 2007 12:08 PM
